Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
firewall drop SIP 200 OK
hello everyone
who can help me
i have a evironment like the top
a CUCM use BIB record by sip recorder
the CUCM will send invite to sip recorder
but when the sip recorder response the INVITE with 200OK , the firewall drop the packet
the reason is CSeq missing ,like following(this is firewall log)
[BEGIN] 2012/7/26 14:37:14
SIP:found content length 0, ctx->dlen 4
SIP::INVITE received from inside:10.10.10.25/48749 to outside:172.16.5.68/5060
SIP::regex engine has reached end of packet
SIP::Found CSeq 101 INVITE
SIP::Found URI in request line "sip:7778@172.16.5.68:5060" (25)
SIP::Found valid SIP URI: sip:60004@10.10.10.25
SIP::Found From addr "sip:60004@10.10.10.25" (21)
SIP::Found From addr tag "2f3657b6-ce63-4bb2-9a23-3053c69980b6-30272437" (45)
SIP::Found valid SIP URI: sip:7778@172.16.5.68
SIP::Found To addr "sip:7778@172.16.5.68" (20)
SIP::Found Via branch "z9hG4bK11e460097a43" (19)
SIP::Found Via addr "SIP/2.0/TCP 10.10.10.25:5060;branch=z9hG4bK11e460097a43" (55)
SIP::Found Max-Forwards 70
SIP::Found Call-ID 1d45a200-101e53d-64b-190a0a0a@10.10.10.25 (41)
SIP::Found Expires, 180 seconds
SIP::Found valid SIP URI: sip:60004@10.10.10.25:5060
SIP::Found Contact sip:60004@10.10.10.25:5060
SIP::Found Content-length 0
    Found port 5060
    Found port 5060
Via Port 5060
SIP::Found User-Agent
SIP::Found Call-Info
    Found port 5060
SIP::Found Expires, 1800 seconds
    Found port 5060
SIP::Not updating database for Contact 10.10.10.25/5060, registry database total 0
Created SIP session for inside:10.10.10.25/48749 to outside:172.16.5.68/5060, 7 total
    From: sip:60004@10.10.10.25 (21);tag=2f3657b6-ce63-4bb2-9a23-3053c69980b6-30272437 (45)
    To: sip:7778@172.16.5.68 (20)
    Call-ID: 1d45a200-101e53d-64b-190a0a0a@10.10.10.25 (41)
Created SIP Transaction for inside:10.10.10.25/48749 to outside:172.16.5.68/5060
    CSeq: 101 INVITE
    Branch: z9hG4bK11e460097a43
SIP:: Proxy forward 1041 bytes, total 1041
SIP::Found From addr tag "2f3657b6-ce63-4bb2-9a23-3053c69980b6-30272440" (45)
SIP::Found Via branch "z9hG4bK11e513f2e798" (19)
SIP::Found Via addr "SIP/2.0/TCP 10.10.10.25:5060;branch=z9hG4bK11e513f2e798" (55)
SIP::Found Call-ID 1d45a200-101e53d-64c-190a0a0a@10.10.10.25 (41)
    Found port 5060
    Found port 5060
Via Port 5060
    Found port 5060
    Found port 5060
Created SIP session for inside:10.10.10.25/48749 to outside:172.16.5.68/5060, 8 total
    From: sip:60004@10.10.10.25 (21);tag=2f3657b6-ce63-4bb2-9a23-3053c69980b6-30272440 (45)
    Call-ID: 1d45a200-101e53d-64c-190a0a0a@10.10.10.25 (41)
    CSeq: 101 INVITE
    Branch: z9hG4bK11e513f2e798
SIP:: Proxy forward 1040 bytes, total 1040
SIP:found content length 210, ctx->dlen 214
SIP::200 received from outside:172.16.5.68/5060 to inside:10.10.10.25/48749
    Found port 5060
Via Port 5060
    Found port 5060
SIP::Expires is in Date format
SIP: Media port 10003
SIP::session level connection addr 172.16.5.68, media port 10003
SIP::media level connection addr 172.16.5.68, media port 10003
SIP::Embedded media port 10003 found in SDP with session IP 172.16.5.68
SIP::Audio port 10003 found in SDP
SIP:: Mandatory field Cseq is missing
SIP::Parse Message failed!
    Found port 5060
Via Port 5060
    Found port 5060
SIP: Media port 10002
SIP::session level connection addr 172.16.5.68, media port 10002
SIP::media level connection addr 172.16.5.68, media port 10002
SIP::Embedded media port 10002 found in SDP with session IP 172.16.5.68
SIP::Audio port 10002 found in SDP
[END] 2012/7/26 14:38:12
the attachment is i capture form firewall inside and outside interface
Everyone's tags (5)
1 ACCEPTED SOLUTION
Hi Bro
Please do copy and paste the configs shown below into your FW and re-test the connnection. If this doesn't work, please paste your latest config here, so that everyone here can assist you.
policy-map global_policy
class inspection_default
  no inspect h323 h225
  no inspect h323 ras
  no inspect skinny
  no inspect sunrpc
  no inspect xdmcp
  no inspect sip
P/S: If you think this comment is helpful, please do rate them nicely :-)
Warm regards, Ramraj Sivagnanam Sivajanam Technical Specialist/Service Delivery Manager – Managed Service Department
Bo,
The ASA is not seeing it, I dont know why. I can see it on the packet capture the field is not missing rather than the ASA is not seeing it. As per the RFC, the INVITE comes with the same Cseq. The RFC specified that if it is not a new request, the Cseq should remain the same and I dont see it changing for the same INVITE session.
  CSeq or Command Sequence contains an integer and a method name.  The
   CSeq number is incremented for each new request within a dialog and
   is a traditional sequence number.
20.16 CSeq
   A CSeq header field in a request contains a single decimal sequence
   number and the request method.  The sequence number MUST be
   expressible as a 32-bit unsigned integer.  The method part of CSeq is
   case-sensitive.  The CSeq header field serves to order transactions
   within a dialog, to provide a means to uniquely identify
   transactions, and to differentiate between new requests and request
   retransmissions.  Two CSeq header fields are considered equal if the
   sequence number and the request method are identical.
This may need a little bit digging, I would like to see this one closely. I will update you soon.
Mike
Mike
hi Maykol Rojas
thanks for you reply
if there no reason , can i config the firewall disable check the packet and passthough the packet???
sorry i dont know firewall...
Hi Bro
How many service-policy do you have in your FW? Assuming it's one (the default), please paste here the output for the command "show service-policy global".
I'm assuming your ACL and PING/network connectivity is good.
Personally, I think this is an issue with the SIP Recoder Server, based on this message "SIP::Found Expires, 180 seconds" but I stand corrected. Is your SIP able to work in a NAT environment?
yes....the sip is able work in a NAT environment.....
except the record,i also use sip call....
following is the call log  200 OK is transfer
[BEGIN] 2012/7/29 9:30:23
SIP::INVITE received from inside:10.10.10.25/5060 to outside:172.16.5.74/5060
SIP::Found URI in request line "sip:13311173269@172.16.5.74:5060" (32)
SIP::Found valid SIP URI: sip:56768001@10.10.10.25
SIP::Found From addr "sip:56768001@10.10.10.25" (24)
SIP::Found From addr tag "2f3657b6-ce63-4bb2-9a23-3053c69980b6-30272512" (45)
SIP::Found valid SIP URI: sip:13311173269@172.16.5.74
SIP::Found To addr "sip:13311173269@172.16.5.74" (27)
SIP::Found Via branch "z9hG4bK1203cc309e6" (18)
SIP::Found Via addr "SIP/2.0/UDP 10.10.10.25:5060;branch=z9hG4bK1203cc309e6" (54)
SIP::Found Call-ID de4a6300-1419207-65c-190a0a0a@10.10.10.25 (41)
SIP::Found valid SIP URI: sip:56768001@10.10.10.25:5060
SIP::Found Contact sip:56768001@10.10.10.25:5060
SIP::Found Content-type application/sdp
SIP::Found Content-length 210
    Found port 5060
    Found port 5060
Via Port 5060
    Found port 5060
SIP: Media port 25628
SIP::session level connection addr 10.10.10.25, media port 25628
SIP::media level connection addr 10.10.10.25, media port 25628
SIP::Embedded media port 25628 found in SDP with session IP 10.10.10.25
SIP::Audio port 25628 found in SDP
Created SIP session for inside:10.10.10.25/5060 to outside:172.16.5.74/5060, 1 total
    From: sip:56768001@10.10.10.25 (24);tag=2f3657b6-ce63-4bb2-9a23-3053c69980b6-30272512 (45)
    To: sip:13311173269@172.16.5.74 (27)
    Call-ID: de4a6300-1419207-65c-190a0a0a@10.10.10.25 (41)
Created SIP Transaction for inside:10.10.10.25/5060 to outside:172.16.5.74/5060
    CSeq: 101 INVITE
    Branch: z9hG4bK1203cc309e6
SIP:: Forward 1150 bytes, total 1150
SIP::100 received from outside:172.16.5.74/5060 to inside:10.10.10.25/5060
    Found port 5060
Via Port 5060
SIP::Found Server
SIP::Found Via addr "SIP/2.0/UDP 10.10.10.25:5060;branch=z9hG4bK1203cc309e6;received=10.10.10.25" (75)
SIP::Found Contact sip:13311173269@172.16.5.74
SIP:: Forward 478 bytes, total 478
SIP::180 received from outside:172.16.5.74/5060 to inside:10.10.10.25/5060
    Found port 5060
Via Port 5060
SIP::Found Server
SIP::Found To addr tag "as0f22e141" (10)
SIP::Unable to open dialog pinhole for  10.10.10.25 to 172.16.5.74/0 from dialog forming 1xx Response
SIP:: Forward 494 bytes, total 494
SIP::183 received from outside:172.16.5.74/5060 to inside:10.10.10.25/5060
    Found port 5060
Via Port 5060
SIP::Found Server
SIP: Media port 19378
SIP::session level connection addr 172.16.5.74, media port 19378
SIP::media level connection addr 172.16.5.74, media port 19378
SIP::Embedded media port 19378 found in SDP with session IP 172.16.5.74
SIP::Audio port 19378 found in SDP
SIP::Found Content-length 179
SIP:: Forward 715 bytes, total 715
SIP::CANCEL received from inside:10.10.10.25/5060 to outside:172.16.5.74/5060
SIP::Found CSeq 101 CANCEL
    Found port 5060
    Found port 5060
Via Port 5060
    CSeq: 101 CANCEL
SIP:: Forward 375 bytes, total 375
SIP::4xx received from outside:172.16.5.74/5060 to inside:10.10.10.25/5060
    Found port 5060
Via Port 5060
SIP::Found Server
SIP:: Forward 465 bytes, total 465
SIP::200 received from outside:172.16.5.74/5060 to inside:10.10.10.25/5060
    Found port 5060
Via Port 5060
SIP::Found Server
SIP:: Forward 449 bytes, total 449
SIP::ACK received from inside:10.10.10.25/5060 to outside:172.16.5.74/5060
SIP::Found CSeq 101 ACK
    Found port 5060
    Found port 5060
Via Port 5060
    CSeq: 101 ACK
Deleted SIP Transaction
    CSeq: 101 ACK
    CSeq: 101 CANCEL
    CSeq: 101 INVITE
SIP::Deleting session for 10.10.10.25 to 172.16.5.74, 0 total
    To: sip:13311173269@172.16.5.74 (27);tag=as0f22e141 (10)
Freeing RTP and RTCP conns
SIP:: Freeing offer dialog conn outside:172.16.5.74/0 to inside:172.16.5.90/5060
SIP:: Freeing signaling conn outside:172.16.5.74/0 to inside:172.16.5.90/5060
SIP:: Forward 414 bytes, total 414
[END] 2012/7/29 9:31:49
this is show service-policy global
some SIP parket is droped
[BEGIN] 2012/7/29 9:39:00
sh ser
IPCC-ASA# sh service-policy g
IPCC-ASA# sh service-policy global
Global policy:
  Service-policy: global_policy
    Class-map: inspection_default
      Inspect: dns preset_dns_map, packet 4868, drop 0, reset-drop 0
      Inspect: ftp, packet 0, drop 0, reset-drop 0
      Inspect: h323 h225 _default_h323_map, packet 0, drop 0, reset-drop 0
               tcp-proxy: bytes in buffer 0, bytes dropped 0
      Inspect: h323 ras _default_h323_map, packet 154717, drop 0, reset-drop 0
      Inspect: rsh, packet 0, drop 0, reset-drop 0
      Inspect: rtsp, packet 0, drop 0, reset-drop 0
      Inspect: esmtp _default_esmtp_map, packet 0, drop 0, reset-drop 0
      Inspect: sqlnet, packet 0, drop 0, reset-drop 0
      Inspect: skinny , packet 57077, drop 0, reset-drop 0
      Inspect: sunrpc, packet 0, drop 0, reset-drop 0
      Inspect: xdmcp, packet 0, drop 0, reset-drop 0
      Inspect: sip , packet 773, drop 76, reset-drop 0
               tcp-proxy: bytes in buffer 0, bytes dropped 16253
      Inspect: netbios, packet 19367, drop 0, reset-drop 0
      Inspect: tftp, packet 2, drop 0, reset-drop 0
      Inspect: ip-options _default_ip_options_map, packet 0, drop 0, reset-drop 0
IPCC-ASA#
[END] 2012/7/29 9:39:18
Hi Bro
  no inspect h323 ras
  no inspect skinny
  no inspect sunrpc
  no inspect xdmcp
  no inspect sip
My dear Jesus....
Suuure it will solve it....
This is an inspection issue, the firewall is not seeing a field that it is in fact there... I wouldnt recommend at all removing the inspections for security purposes and besides the clear Fact that the ASA wont be able to re-write the embedded IP addresses on the SIP requests, in other terms... it may break your Voice Over IP infraestructure... (if you have any besides this issue you are facing).
I would recommend you to open a ticket with TAC, if you want I can look it myself....
Mike
Mike
2643
