Firewall Failover Monitoring Issue in HA Mode
I have configured the two FW for HA mode, and I am checking " sh Failover " I am unable to understand why it’s showing only two interface in monitoring.  It should show all 4 interface in monitoring. I have highlighted in below configuration.
I am very new for FW, below is my complete FW configuration, I'll appreciate for your help to me, if i am missing anything in my configurations ie. means routing / VLAN ........
TechMFWPRIM# sh fail
Failover On
Failover unit Primary
Failover LAN Interface: HA-SYNC Management0/0 (up)
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Poll frequency 5 seconds, holdtime 25 seconds
Interface Policy 1
Monitored Interfaces 2 of 110 maximum
failover replication http
Version: Ours 8.4(2), Mate 8.4(2)
Last Failover at: 04:10:31 UTC Jun 7 2012
        This host: Primary - Active
                Active time: 21300 (sec)
                slot 0: ASA5510 hw/sw rev (2.0/8.4(2)) status (Up Sys)
                  Interface Outside_Data (172.16.1.2): Normal (Waiting)
                  Interface INSIDE (10.28.63.17): Normal (Not-Monitored)
                  Interface CDMZ (10.28.63.33): Normal (Not-Monitored)
                  Interface Outside_Voice (172.16.2.2): Normal (Waiting)
                slot 1: empty
        Other host: Secondary - Standby Ready
                Active time: 80510 (sec)
                  Interface Outside_Data (0.0.0.0): Normal (Waiting)
                  Interface INSIDE (10.28.63.18): Normal (Not-Monitored)
                  Interface CDMZ (10.28.63.34): Normal (Not-Monitored)
                  Interface Outside_Voice (0.0.0.0): Normal (Waiting)
                slot 1: empty
Stateful Failover Logical Update Statistics
        Link : Unconfigured.
TechMFWPRIM#
TechMFWPRIM(config)# sh run
: Saved
ASA Version 8.4(2)
hostname TechMFWPRIM
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
description Outside Airtel_Data
nameif Outside_Data
security-level 0
ip address 172.16.1.2 255.255.255.252
interface Ethernet0/1
description Inside Airtel LAN Interface
no nameif
no security-level
no ip address
interface Ethernet0/1.102
vlan 102
nameif INSIDE
security-level 100
ip address 10.28.63.17 255.255.255.240 standby 10.28.63.18
interface Ethernet0/2
no nameif
no security-level
no ip address
interface Ethernet0/2.100
description CDMZ
vlan 100
nameif CDMZ
security-level 50
ip address 10.28.63.33 255.255.255.240 standby 10.28.63.34
interface Ethernet0/3
description Outside_Voice
nameif Outside_Voice
security-level 0
ip address 172.16.2.2 255.255.255.252
interface Management0/0
description LAN Failover Interface
ftp mode passive
pager lines 24
logging asdm informational
mtu Outside_Data 1500
mtu INSIDE 1500
mtu CDMZ 1500
mtu Outside_Voice 1500
failover
failover lan unit primary
failover lan interface HA-SYNC Management0/0
failover interface ip HA-SYNC 192.168.3.1 255.255.255.0 standby 192.168.3.2
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
route Outside_Data 0.0.0.0 0.0.0.0 172.16.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 10.28.0.0 255.255.255.240 INSIDE
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet 0.0.0.0 0.0.0.0 INSIDE
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username TIMFW password c.6Nu5hdpSeNFjvS encrypted
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:39242421493f5e1e7e9039247fa4ac00
: end
Reg
Sanjeev
By default Cisco ASA in Failover monitors only physical interfaces with configured nameifs and ip addresses.
Monitoring of subinterfaces is disabled by default.
To enable monitoring of subinterfaces use command (in your case) :
monitor-interface INSIDE
monitro-interface CDMZ
Hi Serqey,
Thanks let me try...this will update you shortly the progress.
Just one more help, pls. check the above FW configurations and suggest if i am missing anything
Sanjeev
In your config you have command failover replication http, without stateful failover this command is useless.
you can enable stateful failover (in your case) with the command:
failover link HA-SYNC
so now your active ASA replicates state information to the standby one; by default http is not replicated, so we have to use failover replication http command to enable it
1089
