Firewall Hangs - Help!
I have apix 515 firewall, that occassionally stops new connections being established from the internal zone to the external zone (i.e internet). So for example I may no konger be able to browse websites.
I have found that if I run the "clear xlate" command operations return to normal, however this isn't really a solution.
Could somebody please tell me how I can go about to debug this, what kind of commands should I run. Incidentally I'm running NAT aswell.
Dan
1 REPLY
Re: Firewall Hangs - Help!
The problem is with you your xlate timeout interval and you are either running out of xlates or NAT pool address.
a) Decrease the xlate timer using
timout xlate command
b) Try adding more addresses to your global pool
123
