Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Firewall help
Hello all,
I'm new to the cert world and i'm studying for my ccsp now..
however i have a slight confusing regarding " application firewalls" and "deep inspection firewalls" .Can anyone kindly point out the difference to me if there exists one?
Thx,
YB
Silver
Re: Firewall help
See in simple definations:
Application firewall : Looks like a proxy. You can stop th attack smaller no of amount.
Ex: Linux proxy or older days Checkpoint.
Deep Inspection Firewall: It detects/protects signature based attack, worms etc. Ex: IDS and IPS. It supports large amount of attacks at a time.
Dharmesh Purohit
Community Member
Re: Firewall help
Thanks purohit,
so basically what you are saying is that app firewalls are designed for smaller attacks whereas deep inspection firewalls are designed for more advanced attacks?
Both the firewalls do need separate engines for each application layer protocol they support right?
YB
Silver
Re: Firewall help
If you have IDS Sendor, it detects the attack and IPS pushes the policy based on signature blocked.
Dharmesh Purohit
130
