Firewall reverse routing issue:
sanju250.shukla
Dear Friends,
I am using ASA 5505 with base license and ISP connected directly on the firewall.While L# switch is connected through firewall also.
my configuration is :
ASA Version 7.2(4)
hostname CiscoFirewall03316
domain-name default.domain.invalid
enable password Ko5SCsPM2YQ1wt2G encrypted
passwd Ko5SCsPM2YQ1wt2G encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 10.192.32.11 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 112.23.24.25 255.255.255.248
interface Vlan10
no nameif
security-level 90
ip address 192.168.0.3 255.255.240.0
<--- More --->
interface Vlan50
no nameif
security-level 80
ip address 10.195.32.15 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
switchport access vlan 10
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
switchport access vlan 50
interface Ethernet0/6
interface Ethernet0/7
<--- More --->
ftp mode passive
clock timezone IST 5 30
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
name-server 121.242.190.181
name-server 121.242.190.210
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list in_out extended permit ip any any
access-list out_in extended permit ip any any
access-list out_in extended permit ip any 112.23.24.25 255.255.255.248
access-list cisco_splitTunnelAcl standard permit 0.0.0.0 255.255.255.0
access-list cisco_splitTunnelAcl_1 standard permit any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool ciscouser 10.10.10.240-10.10.10.249 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any outside
<--- More --->
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
access-group in_out in interface inside
access-group out_in in interface outside
route inside 192.168.0.0 255.255.240.0 192.168.0.2 1
route outside 0.0.0.0 0.0.0.0 112.23.24.25 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
http server enable
http 10.192.32.0 255.255.255.0 inside
http 112.23.24.0 255.255.255.248 outside
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set TRANS_ESP_DES_SHA esp-des esp-sha-hmac
crypto ipsec transform-set TRANS_ESP_DES_SHA mode transport
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
<--- More --->
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-DES-SHA
crypto dynamic-map outside_dyn_map 40 set pfs
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-DES-SHA
crypto dynamic-map outside_dyn_map 60 set pfs
crypto dynamic-map outside_dyn_map 60 set transform-set ESP-DES-SHA
crypto dynamic-map outside_dyn_map 80 set pfs
crypto dynamic-map outside_dyn_map 80 set transform-set TRANS_ESP_DES_SHA
crypto dynamic-map outside_dyn_map 100 set pfs
crypto dynamic-map outside_dyn_map 100 set transform-set ESP-DES-SHA
crypto dynamic-map outside_dyn_map 120 set pfs
crypto dynamic-map outside_dyn_map 120 set transform-set ESP-DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption des
hash sha
group 2
lifetime 86400
client-update enable
no vpn-addr-assign aaa
no vpn-addr-assign dhcp
<--- More --->
telnet 10.192.32.0 255.255.255.0 inside
telnet 0.0.0.0 0.0.0.0 outside
telnet 112.23.24.0 255.255.255.0 outside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
group-policy DefaultRAGroup internal
group-policy DefaultRAGroup attributes
dns-server none
vpn-tunnel-protocol l2tp-ipsec
group-policy cisco internal
group-policy cisco attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value cisco_splitTunnelAcl_1
username test password tFqxsrS5ErBk4STW encrypted privilege 0
username test attributes
vpn-group-policy cisco
username admin password V5OS2TRb/vQZ7oZ9 encrypted
username ciscouser password 6aU35/UOvPoumpKWCFYSig== nt-encrypted privilege 0
username ciscouser attributes
vpn-group-policy DefaultRAGroup
<--- More --->
tunnel-group DefaultL2LGroup ipsec-attributes
pre-shared-key *
tunnel-group DefaultRAGroup general-attributes
address-pool ciscouser
default-group-policy DefaultRAGroup
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *
tunnel-group DefaultRAGroup ppp-attributes
no authentication chap
authentication ms-chap-v2
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
<--- More --->
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
policy-map type inspect im Google
parameters
match protocol msn-im yahoo-im
  drop-connection log
service-policy global_policy global
prompt hostname context
Cryptochecksum:a883391680fa205ee31f05881761958c
: end
Everything is running fine on vlan 1 but vlan 10 is not running from user end.there is no ping from inside of 192.168.0.2
Please advise me.Thanks
Jennifer Halim
There are 2 conflicting configuration:
interface Vlan10
no nameif
security-level 90
and "route inside 192.168.0.0 255.255.240.0 192.168.0.2 1"
How do you want to connect VLAN 10? is it on its own interface on the firewall? if it is, then you would need to configure a name for it, via the nameif command, and remove the above route inside
if it is going to be a routed subnet via the inside interface, then the above route needs to be modified as follows:
route inside 192.168.0.0 255.255.240.0 10.192.32.x
--> 10.192.32.x needs to be the next hop which is your L3 switch vlan 1 interface ip
and you would also need to shutdown interface vlan 10 on the ASA and remove the IP Address.
rizwanr74
Level 7
Level 7
Hi Sanjeev,
You need a name on the vlan10, which is missing, so you can name it as inside2 or dmz whatever a meaningful name.
interface Vlan10
nameif inside2
nat (inside2) 1 0.0.0.0 0.0.0.0
Let me know, if this helps.
thanks
