flow denied error
Drop-reason: (acl-drop) Flow is denied by configured rule eeror on asa
When i run the packet tracer i am geeting above eeror
Phase 1 is up
But when i excute show crypto ipsec sa
i am not geeting any result
Please suggest
As check access-list, transformset from both side is matching
Put when ever i access the far end server Phase 1 is active but not able to access
  • Firewalling
1 REPLY
flow denied error
I think the packet-tracer tool generates a real packet, wich will need the sa to be established.
Your ipsec tunnel is not established, if you don´t have an ipsec sa.
What output does the monitor-log bring if you try to establish the tunnel?
Try debugging for more information:
debug crypto ipsec, dont forget the term moni.
The output from both sides should help you to find the mistake in the configuration.
392
