FreePBX (asterisk) Sipstation Cisco ASA 5520 Trunks Won't Register
FreePBX (asterisk) server ip 10.7.4.23
The is is what Sipstation is telling me they are seeing on their end:
2013-09-05 16:31:42.702739 [WARNING] SIP auth challenge (REGISTER) for [XXXXXX@trunk1.freepbx.com] from ip 10.7.4.23
So my ASA is showing the sipstation servers my internal IP address and not the external IP.
I can't setup a static nat for 5060 as I get an error: NAT unable to reserve ports.  I think this is because of the inspection map.
I have tried unchecking sip and H.323 in the service policy rules.
I also get these in the syslog
6Sep 06 201311:06:12
10.7.4.235060192.159.66.3
Pre-allocate SIP SIGNALLING UDP secondary channel for inside:10.7.4.23/5060 to outside:192.159.66.3 from OPTIONS message
Pre-allocate SIP Via UDP secondary channel for inside:10.7.4.23/5060 to outside:192.159.66.3 from OPTIONS message
Hall of Fame Super Gold
Wrong forum, post in "Security - firewalling". You can move your posting with the Actions panel on the right.
thanks I have now moved it.  Bump for some help!
Can u share the NAT configuration you have so far?
For more information about Core and Security Networking follow my website at http://laguiadelnetworking.
Any question contact me at jcarvaja@laguiadelnetworking.com
Cheers,
Julio Carvajal Segura
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Let me know if you need something different.  My phone server has been offline ever since I switched to this ASA...
Manual NAT Policies (Section 1)
1 (inside) to (outside) source static any any   destination static NETWORK_OBJ_172.23.100.128_25 NETWORK_OBJ_172.23.100.128_25 no-proxy-arp route-look
up
    translate_hits = 109, untranslate_hits = 109
2 (outside) to (outside) source static NETWORK-2790 NETWORK-2790   destination static NETWORK-3820 NETWORK-3820
    translate_hits = 0, untranslate_hits = 0
3 (inside) to (outside) source static NETWORK-COLO NETWORK-COLO   destination static NETWORK-2790 NETWORK-2790
    translate_hits = 520083, untranslate_hits = 527119
4 (inside) to (outside) source static NETWORK-COLO NETWORK-COLO   destination static NETWORK-3820 NETWORK-3820
    translate_hits = 7494, untranslate_hits = 15189
Auto NAT Policies (Section 2)
1 (any) to (any) source static VMARR01 75.XXX.XXX.62
    translate_hits = 524, untranslate_hits = 519494
2 (any) to (outside2) source static PRTG-Probe interface   service tcp 23560 23560
    translate_hits = 0, untranslate_hits = 1
3 (any) to (outside2) source static VMUtility01 interface   service tcp www www
    translate_hits = 0, untranslate_hits = 964
4 (any) to (any) source static G-O-L-F 75.XXX.XXX.61
    translate_hits = 3806, untranslate_hits = 14287
5 (any) to (outside) source static Lanczak interface   service tcp www www
    translate_hits = 0, untranslate_hits = 88
6 (any) to (any) source static ThreadJacked ThreadJacked-External-IP
    translate_hits = 120, untranslate_hits = 848
7 (any) to (any) source static Eurovagens Eurovagens-External-IP
    translate_hits = 656, untranslate_hits = 5820
8 (any) to (outside) source static VMWIn701 interface   service tcp 3389 3389
    translate_hits = 0, untranslate_hits = 257
Manual NAT Policies (Section 3)
1 (inside) to (outside) source dynamic any interface
    translate_hits = 23949, untranslate_hits = 3
2 (outside) to (outside) source static NETWORK_OBJ_172.23.100.128_25 interface   no-proxy-arp
    translate_hits = 135, untranslate_hits = 0
I think the show run of the ASA will be helpful (the internal Ip address of the PBX server is 10.7.4.23 right?)
Let me know,
Cheers,
Julio Carvajal
819
