From outside to inside access ( number of static map)
HI
I have two office A and B. A is head office where have 200 user and in B offcie has 300 user.
From A to B connect sceniro:
Boffice-Router-outsideFWinside-A office.
my Goal is all user From office B can access all PC in office A. As office A in behind ASA then I need 200 static Map.
As usual we do point to point static map.
its eassy for some of server or user pc.
As in my sceniro a lot of number pc access so its difficult configure 200 static map. so have any other way ?
Regrads
Biplob
1 ACCEPTED SOLUTION
Re: From outside to inside access ( number of static map)
on the firewall, please send me the output of "show logging | inc x"
where x is the IP address you are pinging from.
Is there an ISP link between the two offices?
If yes, is there a VPN tunnel established between the two offices?
If yes, you may use NAT zero.
Thanks.
No ISP Link. Two office are connected via VSAT. no VPN tunnel between two office.
at present 5 sever are static map. but decession now that all pc of Office A are available for office B but its come throw firewall. so I need more 195 static map ?
thanks
Biplob
not really. Use NAT zero and thats it.
But you have to modify your ACLs on the firewall as well to allow the traffic between the 2 offices.
Cheers.
I am confused. pls clear.
At present scenerio example:
pix outside IP: 192.168.10.1
pix inside IP : 192.168.40.10
ACL 101 permit tcp any any
ACL 101 permit Icmp any any
static( ouside, inside) 192.168.10.11 192.168.40.11 0 0
access-group 101 in interface outside.
**As from my office user not connect internet so nat configure in here.
As your suggation if I configure
nat (inside) 0 192.168.40.0 255.255.255.0
then i do not need any static map ????
office B ( 172.16.20.X) can access Office A (192.168.40.X) without any mapping ???.
and can ping direct 192.168.40.X ?
----can you give me a sample configure---
regrads
Biplob
Hi Biplob,
yes, but don't use:
since you still need traffic going from office A to the internet to be NATed.
So use an ACL like below:
access-list inside-to-outside-NAT-EXCLUDE line 1 extended permit ip 192.168.40.0 255.255.255.0 172.16.20.0 255.255.255.0
nat (inside) 0 access-list inside-to-outside-NAT-EXCLUDE
The config above allows users in office A to connect to office B. For office B users to connect to office A users, use the config below:
access-list outside-to-inside-NAT-EXCLUDE line 1 extended permit ip 172.16.20.0 255.255.255.0 192.168.40.0 255.255.255.0
nat (outside) 0 access-list outside-to-inside-NAT-EXCLUDE.
* Please use the rating system once your problem is solved.
Moath.
If I understand then according to your summary:
office B(172.16.20.0)-FW-OfficeA(192.168.40.0)
Only B office user access to office A then:
B office user access to office A and also users of office A connect to Internet then:
beside this i do not need any other config/
regrads
Biplob
hi,
From office A to office B:
From office B to A:
Please configure all above to allow traffic from both offices.
"beside this i do not need any other config"
Please make sure that the traffic ACLs applied on the outside interface and inside interface (if any) allow the traffic between the 2 offices.
too much thanks. Now I am clear 90 %. now a little bit confution.
1. your last line tell --Please make sure that the traffic ACLs applied on the outside interface and inside interface --- by this line which you meaning ,--it is regrading access group applied interface ?
i don not need any access -group ?
2. you mention example
office B to office A:
and Both.
but If I need additional that
office B to office A and office A connect to Internet. that means office A users also connect to internet then time what I do.
pls give me an example aditionaly. becuse I am worried that if I give no nat exclude 192.168.40.0 then no user of office A can not connect internet.
sorry for your time kill.
regrads
Biplob
1- traffic from outside to inside is denied by default, so you have to allow it in the acl applied on the outside interface.
2- The reason why we used an ACL in the NAT zero statement was to exclude only traffic between the 2 offices from getting NATed.
But there should be another NAT statement for traffic from office A in order to allow it internet access.
If you are confused, plz attach the firewall config to help you more.
ok , i checkout this.
lol... Check out what?
dummy implement and give your result within some time
Dummy results, plz check below ;) cheers mate
result is 0 . i send you the configation what i do. pls wait 5 min.
pls check attachment
Show running access-group, then modify the ACL applied on the outside interface to allow office's B range to connect to office's A range.
like this sceniro have any document or you can send me full configuration ?. i am trying in my lab but failed.
my e-mail address biplobk2000@yahoo.com.
May I introduce with you.
thanks
biplob
I do additionaly
access-list 102 permit icmp any any
access-list 102 permit Ip any any
access-group 102 in interface outside
then also configure
access-list 101 permit ip 192.168.16.0 255.255.255.0 192.168.40.0 255.255.255.0
nat (outside) 0 access-list 101 [this line give warning]
regrads
Biplob
Please remove the settings you applied and try these:
Cheers
Its a good news that your last pescription is right and I reach my destination goal and confused zero. before this test I know that out side user can access inside only by static map.
Too much thanks and warm regards to you for co-operation the test.
Be well and next time see you again.
regrads
Biplob
189
