FSWM Routed Context Issue
I have configured routed context in FWSM but it's not communication event with outside and inside directly connect router (MSFC). When I try to ping outside router IP address it show error in debug.
Denied ICMP type=0, code=0 from 192.168.15.5 on interface outside
I have configured IP any any and ICMP any any on both interfaces.
2 ACCEPTED SOLUTIONS
Re: FSWM Routed Context Issue
Can you configure "icmp permit any outside" and then try pinging again and see if you get a response.
Arul
*Pls rate if it helps*
As I said earlier in order to ensure that the Ping reply reaches FWSM you need to use "icmp permit any outside" command.
ACLs are only used for traffic through the FWSM .
Syed Iftekhar Ahmed
Arul
Add the following
access-list 209 extended permit icmp any any
Syed Iftekhar Ahmed
I have already permited ICMP on both interfaces. but the problem is still there.
Are you pinging from the FWSM or from a host connected to inside interface?
If you are pinging from the FWSM and not "through" the fwsm the ping is permitted or denied based on the icmp command.
Use
icmp permit 0 0 outside
If it were a ping through the FWSM it would
be controlled via an ACL.
Syed Iftekhar Ahmed
I am Ping it from FWSM and ACL configured for ICMP on both intface (inside, outside).
Syed Iftekhar Ahmed
120
