Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
FWSM 3.2(3) and failover
sh monitor-interface
This host: Secondary - Active
Interface a (1.2.3.4): Normal
Interface inside (1.2.4.5): Normal
Interface outside (1.2.5.6): Normal
Other host: Secondary - Standby Ready
Interface a (1.2.3.5): Normal
Interface inside (1.2.4.6): Normal
Interface outside (1.2.5.7): Normal
could someone say whether the stats from primary FWSM is this "This host: Secondary - Active" Is this a cosmetic bug? because I expected Primary - Active
thanks
michael
1 REPLY
Community Member
Re: FWSM 3.2(3) and failover
For some reason your firewall cluster must have trigged a failover from primary to secondary.
Using the command "failover preemtp [delay]"
will force the cluster to reestablish the original state if no failover issue exists anymore.
You can also flip the active and standby by using the command "no failover active" on the active peer.
128
