FWSM Active/Active Failover ICMP replication
I have an issue with WS-SVC-FWM-1 module - in the active/active failover it doesn't make ICMP connection state replication with asr-groups configured on the respective interfaces. Although other connections are working just fine (asymmetric routing is verified with 'show ip cef' on the MSFC) it seems that only newer ASAs are doing ICMP replication in failover, but I couldn't find any documentation describing replication behavior for the FWSM. Can anyone
clearly describe FWSM's behavior for this?
1 REPLY
VIP Green
What FWSM version are you running?
Please remember to rate and select a correct answer
132
