FWSM Basic question
Hello to everyone:-
i need guidence regarding FWSM. i am runing FWSM in my poroduction network and first time i am try to add and assigne one vlan to Fwsm.
i know the command which assigne vlan to FWSM that is below:
firewall vlan-group 1 vlan-id......
currently in my production  this command runing on FWSM.
firewall vlan-group 20  20,30-40,50
but i want to know if i want to add vlan 100 and assigne it to the FWSM whcih command is perfect.
1)Firewall vlan-group 20  20,30-40,50,100
2) Or just need firewall vlan-group 20  100. After executing this command vlan 100 will appended to old configration.
i am asking this question because i am little bit confuse may be command 2 will remove the previous vlan or append vlan 100 in the FWSM configration.
Thansk to the whole community.
  • Firewalling
1 REPLY
Super Bronze
FWSM Basic question
Check out this document
http://www.cisco.com/en/US/docs/security/fwsm/fwsm32/command/reference/ef.html#wp1639443
Its the command reference for FWSM but lists some IOS commands too
It seems to suggest that you can only remove Vlans from the "firewall vlan-group" if you were to use the "no" parameter in front of the actual command.
I have personally usually only had the need to add or remove a single vlan and I have used the command as you describe.
As in "firewall vlan-group "
- Jouni
71
