FWSM - clear arp entry
Can someone advice the command the clear a single mac-address entry on the FWSM arp table?
TIA
PF
Re: FWSM - clear arp entry
try clear arp ip_address, where nameif is the interface name, see if that works.
Jorgemcse,
It didn't work. Came out with
FWSM# clear arp inside 10.1.1.199
ERROR: % Invalid input detected at '^' marker.
Thanks.
PF
try no arp inside 10.1.1.199, it will clear arp for that host but once host is ping from fw it will be in arp table again.
Rgds
Jorge
Jorge,
thanks very much. It works.
PF
Thanks, Jorge. That command
Thanks, Jorge. That command worked for me too!
4533
