FWSM Continuous Reload of Standby Unit due to Synchronization Problem
Hi, the following error message apears in the secondary FWSM unit:
Config Sync Error: Following command could not be executed on standby
access-list privilegeados commit-status committed line 83 extended permit ip host 172.26.55.67 any time-range VERASLAB#5PIEDRAS
Context: single_vf
******REPLICATION OF CONFIGURATION FROM ACTIVE TO STANDBY UNIT IS INCOMPLETE,
TO PREVENT THE STANDBY UNIT TAKING OVER AS ACTIVE WITH A PARTIAL CONFIGURATION,
THE STANDBY UNIT WILL NOW REBOOT*******
In the begging I tought it was a lack of resources, but I'm using single context mode and have enough free resources.
The following message appears on the 7600 primary unit: %SVCLC-5-FWTRUNK: Firewalled VLANs configured on trunks
I removed the ACL and the standby FWSM unit stop rebooting.
¿What can be causing this problem?
Re: FWSM Continuous Reload of Standby Unit due to Synchronizatio
what code FWSM is running?
Hi, I have the following configuration applied:
interface Vlan201
nameif inside
security-level 100
ip address X.X.X.X X.X.X.X standby X.X.X.X
interface Vlan210
nameif outside
security-level 0
ip address Y.Y.Y.Y Y.Y.Y.Y standby Y.Y.Y.Y
failover
failover lan unit primary
failover lan interface f_over Vlan211
failover interface ip f_over Z.Z.Z.Z Z.Z.Z.Z standby Z.Z.Z.Z
monitor-interface inside
monitor-interface outside
The FWSM is version:
FWSM Firewall Version 3.2(2)
Not sure if it is a bug but I did not find one so far.
So you removed that ACL entry to fix the issue?
Can you try to add time-range config first and then sync the config between active and standby? and then config that ACL entry and try to sync config again.
You might need open a TAC case to furhter investigation.
Yes, I removed the ACL and the standby FWSM unit stop rebooting.
I'll tried with your recommendations and I'll let you know.
Thanks a lot for your help.
323
