FWSM Failover on VSS environment
Is FWSM Failover feature supported on a VSS environment? We currenlty have two 6509 with FWSM on both switches. VSS is currently enabled and I would also want to enable the failover on the FWSM. The current IOS running is s72033-adventerprisek9_wan-vz.122-33.SXI. Thanks
Re: FWSM Failover on VSS environment
Yes, FWSM works together with VSS as of FWSM release 4.0.4 (I'd suggest going for latest in 4.0 train).
edited: version numbers as per:
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/product_bulletin_c25-478751.html
Thanks for your reply. How about the configuration? Will it be transparent? I can't find any configuration guide on FWSM failover on a VSS environment. Hope you can help. Thanks
Well the FWSM (from config point of view) is not aware whether the setup is VSS, same way it's not aware if the blades in failover are in same or different chassis.
My bad!
Sorry for that 4.0.4 is the release supporting VSS. Sorry for this blunder.
So after I upgrade my FWSM to 4.0.4. I will just use the same configuration like the one below?
hostname(config)# failover lan unit primary
hostname(config)# failover lan interface if_name vlan vlan
hostname(config)# failover interface ip if_name ip_addr mask standby ip_addr
For the VLAN, Will it be the same as the VLAN used by VSS?
Well, normally you should split data vlans from failover vlan (requirement) and stateful link vlan (suggested). It's best practice.
I would not recommend mixing VSL and failover vlans - I'm not sure if any parser would complain though.
Thanks! Will test the configuration. And will let you know if I have more inquiries.
1062
