08-21-2013 04:22 AM - edited 03-11-2019 07:28 PM
Dear experts,
May I ask for your help in enabling failover between two fwsm in 6509 vss setup. When i checked the output of the " show failover" command I am seeing "Version: Ours 4.1(9), Mate Unknown" and the configuration from the primary unit is not being replicated to the secondary unit.
Thank you very much and appreciate your kind help.
##show version on primary fwsm##
dc-fwsm1 up 16 mins 33 secs
failover cluster up 16 mins 33 secs
Hardware: WS-SVC-FWM-1, 1024 MB RAM, CPU Pentium III 1000 MHz
Flash STI Flash 8.0.0 @ 0xc321, 20MB
0: Int: GigabitEthernet0 : address is 0023.336a.f180, irq 5
1: Int: GigabitEthernet1 : address is 0023.336a.f180, irq 7
2: Int: EOBC0 : address is 0000.1300.0000, irq 11
The Running Activation Key is not set, using default settings:
Licensed features for this platform:
Maximum Interfaces : 256
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
BGP Stub : Disabled
Service Acceleration : Disabled
VPN Peers : Unlimited
##failover config on primary fwsm##
dc-fwsm1# sh run | grep failover
failover
failover lan unit primary
failover lan interface fover Vlan255
failover replication http
failover link flink Vlan256
failover interface ip fover 10.60.28.5 255.255.255.252 standby 10.60.28.6
failover interface ip flink 10.60.28.9 255.255.255.252 standby 10.60.28.10
##interface status on secondary fwsm##
dc-fwsm1# sh int ip br
GigabitEthernet0 unassigned YES unset up up
GigabitEthernet1 unassigned YES unset up up
Vlan251 10.30.2.1 YES CONFIG up up
Vlan252 10.60.21.1 YES CONFIG up up
Vlan253 10.60.3.1 YES CONFIG up up
Vlan255 10.60.28.4 YES CONFIG up up
Vlan256 10.60.28.9 YES CONFIG up up
Vlan350 192.168.100.2 YES CONFIG up up
EOBC0 127.0.0.31 YES CONFIG up up
##show version on secondary fwsm##
FWSM Firewall Version 4.1(9)
Compiled on Fri 04-May-12 11:38 by fwsmbld
dc-fwsm2 up 11 mins 58 secs
failover cluster up 11 mins 58 secs
0: Int: GigabitEthernet0 : address is 0023.336a.ec80, irq 5
1: Int: GigabitEthernet1 : address is 0023.336a.ec80, irq 7
VPN-DES : Enabled
Guards : Enabled
GTP/GPRS : Disabled
BGP Stub : Disabled
##failover config on secondary fwsm##
dc-fwsm2# sh run | grep failover
failover
failover lan unit secondary
dc-fwsm2# sh int ip brief
Vlan255 10.60.28.5 YES CONFIG up up
Vlan256 10.60.28.10 YES CONFIG up up
08-21-2013 04:28 AM
Dear
There is one command that sync two FWSM to each other for failover in VSS.i cannot relocllect that but you have to put.
firewall switch 1 XXXXX
firewall switch 2 XXXXX
08-21-2013 04:37 AM
I already found the cuplrit Now failover and config sync is working.
dc-fwsm1# sh failover
Failover On
Failover unit PrimaryFailover LAN Interface: fover Vlan 255 (up)
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Poll frequency 15 seconds
Interface Policy 50%
Monitored Interfaces 0 of 250 maximum
Config sync: active
Version: Ours 4.1(9), Mate 4.1(9)
Last Failover at: 14:27:08 GMT Aug 21 2013
This host: Primary - Active
Active time: 2243 (sec)
Interface dmz-oss-srv (10.30.2.1): Normal (Not-Monitored)
Interface lan-oss-srv (10.60.21.1): Normal (Not-Monitored)
Interface dmz-hq-srv (10.60.3.1): Normal (Not-Monitored)
Interface fwsm-msfc (192.168.100.2): Normal (Not-Monitored)
Other host: Secondary - Standby Ready
Active time: 1392 (sec)
Interface dmz-oss-srv (0.0.0.0): Normal (Not-Monitored)
Interface lan-oss-srv (0.0.0.0): Normal (Not-Monitored)
Interface dmz-hq-srv (0.0.0.0): Normal (Not-Monitored)
Interface fwsm-msfc (0.0.0.0): Normal (Not-Monitored)
Stateful Failover Logical Update Statistics
Link : flink Vlan 256 (up)
Stateful Obj xmit xerr rcv rerr
General 61 0 60 0
sys cmd 60 0 60 0
up time 0 0 0 0
RPC services 0 0 0 0
TCP conn 0 0 0 0
UDP conn 0 0 0 0
ARP tbl 1 0 0 0
Xlate_Timeout 0 0 0 0
AAA tbl 0 0 0 0
DACL 0 0 0 0
Acl optimization 0 0 0 0
OSPF Area SeqNo 0 0 0 0
Mamba stats msg 0 0 0 0
Logical Update Queue Information
Cur Max Total
Recv Q: 0 1 522
Xmit Q: 0 0 61
08-21-2013 04:46 AM
what was that so others can find this post helpful
