Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
FWSM failover pair on 3.1(3) - OSPF problem?
2x 6513/MSFC with FWSM in each, controlling staff/student access to internal servers. 6513s are trunked together, so vlans 10 and 20 appear on each.
OSPF on all devices.
workstation on vlan10 routes to 6513-A (via hsrp-address)
then via vlan 20 to FWSM-A (active state)
FWSM-A has the same OSPF cost to 6513-A and to 6513-B, which both interface to vlan 10, so FWSM-A has equal-cost routes back to vlan 10 via both switches.
I'm not sure if this IS a problem, but it doesn't sound too clever.
I wanted to try -
router ospf 1
neighbor b.b.b.b cost 100
on the FWSM to "un-equal" the cost, but the command doesn't allow "cost"
Any ideas?
Gold
Re: FWSM failover pair on 3.1(3) - OSPF problem?
can you set the interface cost on the firewall port?
Yes....
FWSM-Server-Firewall(config-if)# ospf cost 100
.... but the new cost then applies to both 6513s - there's no option to specify different costs for different neighbors.
Silver
set channel vlancost {Vlan} 10
set spantree portvlancost 3/47 cost 16 1-1005
set spantree portcost
Dharmesh Purohit
197
