Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
FWSM from a Swtich running Catos
I have a FWSM module running on a Switch that has Catos. I have tried the traditional command, of sess slot proc, and it wont take the command. Can someone tell me what the command would be in order to get into the fwsm.
1 REPLY
Community Member
Re: FWSM from a Swtich running Catos
Hi there,
You are using the command for an IOS based 6500. You need to use the session command in CatOS.
Russell
152
