Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
FWSM in Transparent mode help
Hi all,
i am actually designing for a new solution based on 6509 Switch with FWSM module, here is what i have :
FWSM will be used in Transparent mode with two bridge group : 1 , 2 as mentioned on the image, i wonder if this is a correct deisgn or not, is this will work with no probleme with these two trunk links ?
i've seen on the guidelines of this url :
http://www.cisco.com/en/US/docs/security/fwsm/fwsm22/configuration/guide/fwmode.html#wp1184961
"The transparent FWSM uses an inside interface and an outside interface only. "
is it applicable in my case,
any other information will be welcome.
Thanks for help
252
