FWSM IOS 3.1.8 and higher (issue or my mistake?)
Hello everyone!
I have a C6500 (SUP720+FWSM(IOS 3.1.5)).
Between the SUP and FWSM I have configured interface VLAN50 and enable OSPF on this interface subnet.Everything is working well.Then I upgrade first to 3.1.8 and then to 3.2.4 , with the same configuration on SUP and FWSM and the OSPF process does not get UP.On the SUP debug, I see that it send hello packets to FWSM, no reply.From FWSM I get at debug: "OSPF: Input packet ignored.".L3 connection exist between FWSM and SUP (I can ping each other).The access-list are unmodified, like in 3.1.5, so traffic is allowed.
I believe that I have some mistake.
Can you help me with an advice?
Thank you!
Best regards,
Calin
1 REPLY
Bronze
Re: FWSM IOS 3.1.8 and higher (issue or my mistake?)
When you log in to the FWSM during normal operation, you can copy the application software to the current application partition from a TFTP, FTP, HTTP, or HTTPS server.
http://www.cisco.com/en/US/docs/security/fwsm/fwsm31/upgrade/guide/fwsm31up.html#wp2070189
188
