FWSM & IP Telephony
I need to find out which features does the FWSM posses regarding the handling of ipt traffic / protocols.
Where can I find this data ?
Anonymous
N/A
Re: FWSM & IP Telephony
The FWSM includes many advanced features, such as multiple security contexts that are similar to virtualized firewalls, transparent (Layer 2) firewall or routed (Layer 3) firewall operation, hundreds of interfaces, and many more features.
You are right but this doesn't answer my question that needs specific information about the UC handling.
The FWSM supports inspections/fixups for multiple voip protocols, which one do you need?
http://www.cisco.com/en/US/docs/security/fwsm/fwsm31/configuration/guide/inspct_f.html
Farrukh
112
