Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
FWSM Logging
Dears,
I have a strange problem, the traffic which is allowed through FWSM when it passes it doesn't show me in logging buffer . Connection get established by ssh protocol users sucessful login but when i try to check by sh logging | in 10.10.10.10 there is no logs for the IP address.
I have not disable any messages although i have enabled debug level for buffer but still there are no logs.Below are the configs for the logging in FWSM.
FWSM# sh run | in logging
logging enable
logging timestamp
logging buffer-size 8096
logging asdm-buffer-size 512
logging buffered debugging
logging trap debugging
logging asdm debugging
logging queue 8192
logging host MGMT 172.24.100.100
logging host MGMT 172.24.100.12
Red
FWSM Logging
Hi Jack,
The buffer size seems smaller to me as compared the numbe of logs being generated by the ASA, try chceking it on your syslog server, or you might need to incresae the buffer size:
logging buffer-size
then do:
clear logging buffer
try ssh, and then check the logg again.
Best option I would say is the syslog server, as you would have less chance of losing it.
Hope that helps.
Varun
Thanks, Varun Rao Security Team, Cisco TAC
Community Member
FWSM Logging
thanks for repy varun,
I didnt checked in syslog but i did with clear logging buffer and i trigger the login ssh and then i checked in 5 seconds it was nothing showing me with that IP. I m sure with the IP becz when i start captures it shows me the IP address as source of the packet.
Any more hints,
Community Member
FWSM Logging
can anybody give me hints please where could be wrong for such type of issues.
Thanks.
FWSM Logging
Hello Jack,
Can you dissable the logging service and then re-enable it, maybe the process got stuck.
no logging enable
no logging buffered debugging
logging enable
logging buffered debugging.
Please rate helpful posts,
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
633
