FWSM Memory Management Ver 3.1(5)
We have a FWSM running ver 3.1(5). We are running into memory problems on one of the contexts/partitions. Apart from using the
resource acl-partition <number-of-partitions>
command, is there any way of manually reconfiguring more memory to the particular context which requires the most?
Is there a good webpage with memory management advice for the FWSM?
Senan
Re: FWSM Memory Management Ver 3.1(5)
You can use the "allocate-acl-partition" in the system context to 'dedicate' a memory partition to a particular context. This was this context has 'exclusive' access to this partition, have a look at:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm31/configuration/guide/contxt_f.html#wp1126565
Farrukh
Thanks Farrukh
The context is already in its own memory partition but I'll configure it exclusive now as well.
Senan
I'm sorry this is the only alternate I know of. If you add multiple contexts then they start sharing the partitions. This way you can at least guarantee one partition for this high utilization context.
Farrukh
156
