FWSM Module Active/Standby configuration
Hi all,
I have 3 FWSM modules that I am going to install on 3 different 6509, I am configuring the 3 FW modules in transparent mode with two context in each FWMS module.
Do you know if it is possible to configure the following:
- FWSM A has context 1 active and context 2 active
- FWSM B has context 1 in standby (backup of context 1 in FWSM A)
- FWSM c has context 2 in standby (Backup of context 2 in FWSM A)
The 3 FWSM modules are installed on different switches.
1 REPLY
Hall of Fame Super Blue
Re: FWSM Module Active/Standby configuration
Hi Vicente
To my knowledge you cannot have more than 2 FWSM's in an active/standby scenario.
I believe the problems would come when you come to configure failover on the active unit and try to specify 2 different standy units.
Jon
159
