Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
FWSM module troubles...
Hi...
I have some issue regarding a FWSM module inserted on Catalyst 6509. This module is the stand-by of the primary module resident on other Catalyst 6509 that is fully working. No operations has been made in the failover mode.
Firts of all, I can't connect via "session" command.
If i do a complete hw module test this is the resultant log:
May  6 14:58:08.307: %DIAG-SP-6-TEST_RUNNING: Module 4: Running TestSynchedFabChannel{ID=4} ...
May  6 14:58:08.311: %DIAG-SP-3-TEST_NOT_SUPPORT: Module 4: TestSynchedFabChannel{ID=4} is not supported
May  6 14:58:08.311: %DIAG-SP-6-TEST_RUNNING: Module 4: Running TestFirmwareDiagStatus{ID=6} ...
May  6 14:58:08.323: %DIAG-SP-6-TEST_OK: Module 4: TestFirmwareDiagStatus{ID=6} has completed successfully
May  6 14:58:08.323: %DIAG-SP-6-TEST_RUNNING: Module 4: Running TestAsicSync{ID=7} ...
May  6 14:58:08.323: %DIAG-SP-6-TEST_OK: Module 4: TestAsicSync{ID=7} has completed successfully
May  6 14:58:08.323: %DIAG-SP-6-TEST_RUNNING: Module 4: Running TestErrorCounterMonitor{ID=8} ...
May  6 14:58:08.323: %DIAG-SP-3-TEST_SKIPPED: Module 4: TestErrorCounterMonitor{ID=8} is skipped
May  6 14:59:27.916: %DIAG-SP-6-TEST_RUNNING: Module 4: Running TestPortASICLoopback{ID=1} ...
May  6 14:59:27.916: SP: komodo_plus_test_loopback [4]: On-Demand test is not allowed
May  6 14:59:27.916: %DIAG-SP-3-TEST_SKIPPED: Module 4: TestPortASICLoopback{ID=1} is skipped
May  6 14:59:27.916: %DIAG-SP-6-TEST_RUNNING: Module 4: Running TestPCLoopback{ID=2} ...
May  6 14:59:27.916: %DIAG-SP-3-TEST_SKIPPED: Module 4: TestPCLoopback{ID=2} is skipped
May  6 14:59:27.916: %DIAG-SP-6-TEST_RUNNING: Module 4: Running TestNetflowInlineRewrite{ID=3} ...
May  6 14:59:27.916: %DIAG-SP-3-TEST_SKIPPED: Module 4: TestNetflowInlineRewrite{ID=3} is skipped
May  6 14:59:27.916: %DIAG-SP-6-TEST_RUNNING: Module 4: Running TestFirmwareDiagStatus{ID=6} ...
May  6 14:59:27.928: %DIAG-SP-6-TEST_OK: Module 4: TestFirmwareDiagStatus{ID=6} has completed successfully
If i issue a reset of the module with full mem test I obtain this log:
May  6 15:02:55.465: SP: The PC in slot 4 is shutting down. Please wait ...
May  6 15:02:55.469: %C6KPWR-SP-4-DISABLED: power to module in slot 4 set off (Module  Failed SCP dnld)
May  6 15:03:00.468: SP: shutdown_pc_process:No response from module 4
May  6 15:03:10.469: %SM-SP-4-BADEVENT: Event 'pc_powered_off' is invalid for the current state 'stay_disabled': cygnus_oir_bay slot4
-Traceback= 40DB1EF4 41041CEC 40758968 40758954
May  6 15:03:10.469: SP: Last transition recorded: (disabled)-> stay_disabled (operator_power_on)-> can_power_on (yes_power)-> powered_on (real_power_on)-> check_power_on (timer)-> check_power_on (power_on_ok)-> wait_til_online (powered_off)-> shutdown_pc (disabled)-> disabled (disabled)-> disabled2 (disabled)-> stay_disabled
The commands related to power for the module is fully working. I can power off, power on and shutdown the module properly.
I also change slot for investigate back plane issue related but nothing changed.
Now, what else can I do? Can I extract the CF card and see if I can read through pc?
May I swap the CF from the working module to this module?
Try to remove the module and
Try to remove the module and add it again on the same slot or in different slot, if that does not help, then you need to RMA the module if you have valid support from Cisco.
As mentioned before I've
As mentioned before I've tried to reseat the module in the same slot and also in another slot.. but nothing changed.
But, If I reseat the module without the CF I have this log:
Silver
Hi,The switch has its normal
The switch has its normal vibrations and over time those vibrations can cause a module to slightly come away from the backplane. When this happens, the supervisors keepalive polling does not receive a response from the module within the allotted time and the supervisor reboots the module in order to try to gain a better connection to it. If the module still does not respond to the polls, the supervisor continuously reboots the module, and eventually puts it into error disable and does not allow any power to reach this module.
A simple reseat of the module corrects this issue 90 percent of the time. If you reseat the module, it realigns the switch fabric and ensures a firm connection to the backplane.
Also refer this post
"Please rate helpful posts"
Silver
Then better you go for
Then better you go for replacement
524
