FWSM Multicast Routing on Multiple Mode
when will it be possible to configure multicast-routing on a FWSM running in multiple context routed mode ?
Currently it's just possible for single routed mode
Matthias
Not applicable
I think it is not possible to configure the multicast routing in multiple context routed mode.Refer the below URL for more information:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm32/asdm52f/user/guide/mcast.html#wp1113216
ajagadee
Mathias,
I dont know when there will be support for multicast in multiple context mode. But, one option is you can bridge the multicast packets in Multiple Context Mode by making the context a L2 Firewall.
Multicast bridging is supported
http://www.cisco.com/en/US/docs/security/fwsm/fwsm40/configuration/guide/contxt_f.html#wp1116132
Arul
*Pls rate if it helps*
