fwsm on both 6513 switches problem??
in 6513 switch fwsm moudls and do five vitual context,vitual context work in transparent module ,after the
synchronization end of the two context(show failover is Normal ), the Duplicate address happen in switch console logging. the switch cpu percent is full.6513 is high cpu,that time can't telnet to FWSM.If shutdowm fwsm.cpu immediately change to lower.
When I use single fwsm modul,it only running few minut's(5-6 min's) after reset FWSM.console no any prompt.can't telnet fwsm.But show modul is OK.FWSM_A & FWSM_B is same.
Below 6513 config :
clock timezone PDT -7
firewall multiple-vlan-interfaces
firewall module 1 vlan-group 1
firewall vlan-group 1 2-9,11,12,20,30,40,50,60,70,80,90
analysis module 2 management-port access-vlan 8
ip subnet-zero
spanning-tree mode rapid-pvst
interface Port-channel1 #port-channell To SwitchB
switchport
switchport mode trunk
no ip address
interface GigabitEthernet10/46
switchport
no ip address
channel-group 1 mode desirable non-silent
Below is trade context config:
ZJRCU-FWSM/trade# sh run
: Saved
FWSM Version 3.1(3) <context>
firewall transparent
hostname trade
enable password xxx
names
interface Vlan2
nameif outside
bridge-group 2
security-level 0
interface Vlan20
nameif inside
bridge-group 2
security-level 100
interface BVI2
ip address 10.233.2.250 255.255.255.0 standby 10.233.2.251
passwd 2KFQnbNIdI.2KYOU encrypted
access-list test extended permit ip any any
access-list eth ethertype permit bpdu
pager lines 24
mtu outside 1500
mtu inside 1500
monitor-interface outside
monitor-interface inside
icmp permit any outside
icmp permit any inside
no asdm history enable
arp timeout 14400
access-group eth in interface outside
access-group test in interface outside
access-group eth in interface inside
access-group test in interface inside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
ZJRCU-FWSM/trade# sh fa
Failover On
Last Failover at: 13:49:27 UTC Nov 24 2006
This context: Standby Ready
Active time: 0 (sec)
Interface outside (10.233.2.251): Normal
Interface inside (10.233.2.251): Normal
Peer context: Active
Active time: 469 (sec)
Interface outside (10.233.2.250): Normal
Interface inside (10.233.2.250): Normal
Stateful Failover Logical Update Statistics
Status: Configured.
Stateful Obj xmit xerr rcv rerr
RPC services 0 0 0 0
TCP conn 0 0 0 0
UDP conn 0 0 0 0
ARP tbl 0 0 2 0
L2BRIDGE Tbl 0 0 15 0
Xlate_Timeout 0 0 0 0
ZJRCU-FWSM/trade#
1 REPLY
Re: fwsm on both 6513 switches problem??
I make sure this is loop occur.when i deny any any in interface inside and outside.6513 switch system is normally,cpu is 0%.why i permit ethertype BPDU to avoid loop.it still happen.how to avoid???
163
