FWSM or ASA Configured for VRF
I know that I firewall can pass VRF routed traffic, but can you actually configure a VRF instance on a ASA or FWSM?
thank you,
Kevin
1 ACCEPTED SOLUTION
Bronze
Re: FWSM or ASA Configured for VRF
Kevin,
I think running FWSM/ASA with multiple context is same as having multiple VRFs in router. As using context you can get same functionality as vrf such as separate routing table, ACLs on the per context basis. So each context will act as separate standalone firewall.
Bronze
Kevin,
yagnesh, got it, that makes sense.
very good, thank you
Gold
last time i checked you can't run dynamic routing protocols in multiple context mode.
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/contexts.html#wp1116132
366
