Silver
FWSM problem
we are having 6513 switch with 2*FWSM module.Can anyone tell me how to integrate FWSM .I can create the session on the slots .But after that how to bind the vlans.Please help me i am very much new to this.
regards
shivlu
1 REPLY
Hall of Fame Super Blue
Re: FWSM problem
Hi Shivlu
You "bind" vlans to the FWSM using the following command
On the 6513 chassis (NOT on the FWSM)
firewall module "slot number of FWSM" vlan-group 7 ( 7 is only an example it could be any number )
firewall vlan-group 7 "vlan numbers"
You need to do this on both chassis's
Aftrer this you can connect to the FWSM and create your interfaces etc.
Note that i'm assuming you are not using contexts ie. you are running in single mode.
You don't say what version of software you are using but have a search on Cisco web site with search string
"FWSM configuration" and you should be able to find the relevant guide for your FWSM.
Jon
103
