Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
FWSM, save certificate on secondary unit.
When FWSM generates the self-signed certificate you can save it with write memory command on primary unit. And in the secondary?
Thanks for help!
Andrea
Bronze
Re: FWSM, save certificate on secondary unit.
If the fwsm's are in stateful failover the write memory command will save the certificate to secondary also.
Community Member
Yes, I'm using failover.
After a failover event I must use the crypto command to create the certificate on secondary unit.
The write memory command will save the certificate only to primary unit.
Community Member
Hello Andrea
This is exactly what I am experiencing as well. What was the solution?
Many thanks
Stefan
Community Member
Sorry Stefan but this case is still open for me.
Regards.
Andrea
Community Member
Hi Andrea
Thanks. I'm also still working on that. Maybe I'll have an answer in a few days time. I'll inform you.
Stefan
Community Member
Many thanks for your support Stefan.
Regards.
Andrea
180
