FWSM Stops Forwarding .. corrupting XLATES?
I have a FWSM that seperates various segments on the network. For some reason at times connectivity to some hosts stops without any indication why.
I had done some checking and discovered that there seems to be a corrupt XLATE created at times, which results in the FWSM not forwarding traffic properly.
FWSM1# sh xlate detail | incl FS01
> NAT from wan:FS01 to inside:FS01 flags Ii
> NAT from wan:FS01 to wan:FS01 flags Ii
FWSM1#
We have extended OSPF onto the FWSM. What I noticed this morning was that the routing table changed .. probably around the time the fault was reported.
As can be seen in the extract above ther eis a translation from one interface for FS01 back to the same interface for that same server.
Have tried almost all versions of FWSM code, does not make any difference.
Any Ideas?
  • Firewalling
1 REPLY
Re: FWSM Stops Forwarding .. corrupting XLATES?
Pls. issue "sh run same"
remove "same-security-traffic permit intra-interface"
This will stop these incorrect X-lates from getting created.
Hopefully you do not need that line. You only need that line if you have a need to U-Turn traffic out the same interface where the packet was received on.
196
