FWSM with two outside
Hi ,
I have FWSM with two outside interfaces , is there a way to configure two static route one primary to the first outside , and the other is backup ?
I have read this document , https://supportforums.cisco.com/docs/DOC-12015 It use the command " route-monitor" , but one outside with two gateways in the same subnet .
I tried the same command in my scenario , but I could not add two routes to the same destination pointing to two different gateways in two different subnet .
Also sLA monitor is not supported on FWSM , is there any solution for this scenario ?
Ali
Super Bronze
No unfortunately that is not supported on FWSM.
And you are right, the route-monitor is only supported on the same outside interface, not 2 different outside interfaces.
Thanks Jennifer ,
What about the new ASA Module , I heard that it supports SLA monitor ..
Ali
Super Bronze
Yes, the new ASA-SM does support SLA monitor.
Here is the config guide for the ASA-SM for your reference:
http://www.cisco.com/en/US/docs/security/asa/asa84/configuration85/guide/route_static.html#wp1119813
384
