Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
GRE Tunnel Issues
I have a GRE Tunnel on 2 routers; The tunnel keeps going down.
In the path between the 2 Routers there is a pair of ASA firewalls. Everytime the tunnel goes down, I see a connection on the Firewall that shouldn't be there ;
This is the output from the Firewall:-
Firewall# sh conn | in GRE
GRE internet 10.10.10.10:0 outside  10.230.10.10:0, idle 0:00:05, bytes 5343165, flags
GRE outside 10.230.10.10:0 inside  10.10.10.10:0, idle 0:00:05, bytes 7900, flags
The first connect is not suppose to be there; I am not sure how this connection keeps being established. The 10.10.10.10 range resides on the inside interface of the Firewall, and the 10.230.10.10 resides on the outside ( as you can see on the second connection) which is correct. After I clear the connections on the firewal the GRE tunnel come up immediately.
Everyone's tags (4)
124
