GRE with Static NAT on ASA 5540 running 8.2
I am trying to run below command
access-list test extended permit gre host 192.x.x.x any
static (inside,outside) 59.x.x.x access-list test
after putting static command i get error saying
protocol mismatch between the static and access-list
need help to find if gre protocol is supported using static nat or not as when calling access-list with any port under tcp or udp protocol it works.
Amar
1 ACCEPTED SOLUTION
Re: GRE with Static NAT on ASA 5540 running 8.2
See the syntax per documentation :
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/s8.html#wp1512466
This access list should include only permit ACEs. You can optionally specify the real and  destination ports in the access list using the eq operator.
The protocol you used is not allowed to be used for access-list on Static . You can use tcp or udp,  or topgether  with specific port.
1 REPLY
656
