Group of ports assigned to same Vlan/Network 5585
I want to assign two physical ports to the same vlan essentially, I cant seem to do that on the 5585
1 REPLY
VIP Green
will you have more than that
will you have more than that one VLAN assigned to the port?  If not you could set up the port as an etherchannel.
Otherwise, you can not do this, as it is not supported on the ASA.
Please remember to rate and select a correct answer
-- Please remember to rate and select a correct answer
64
