We have inherited a Cisco wireless lan controller 4400 and about
25 Cisco Aironet 802.11 a/b/g access points. I wanted to set
this up on our ASA 5510 using the inside interface for guest
access( Using the inside interface was the suggestion of a co-worker)
Vlans are setup for the Wireless controller and the
APs to my Wireless switch. If I setup a subinterface of the inside
interface and then setup the vlan for that subinterface how should
I setup the global PAT for that subinterface? And then how would I setup
the ACL to allow the guest access off the APs. I am a little
fuzzy on this so please excuse the possible holes or misinformation.
I just need a little design guidance.
