H.323 Calls disconnecting by TCP idle timeout
We are running "ip inspect" on a 3941 router with IOS version15.2(1)T1. We enabled inspection for H.323 :
ip inspect name iosfw h323
ip inspect name iosfw h323-nxg
ip inspect name iosfw h323-annexe
We are using the default TCP idle-timeout
3945-Router#sh ip inspect config | in tcp
max-incomplete tcp connections per host is 50. Block-time 2 minutes.
tcp synwait-time is 30 sec -- tcp finwait-time is 5 sec
tcp idle-time is 3600 sec -- udp idle-time is 120 sec
tcp reassembly queue length 16; timeout 5 sec; memory-limit 1024 kilo bytes
    tcp alert is on audit-trail is off timeout 3600
After we establish a H.323 call I can see that the inspection process starts the idle timmer on port 1720/TCP and the call is disconnected after an hour with the following log:
%FW-6-DROP_PKT: Dropping h323 session x.x.x.x:17174 y.y.y.y:1720  due to  Segment matching no TCP connection with ip ident 7154 tcpflags 0x5004 seq.no 3486961044 ack 0
This is the sessios incrementing the Last Heard timer:
Session 1C1FB8C (x.x.x.x:17168)=>(y.y.y.y:1720) h323 SIS_OPEN
Created 00:04:07, Last heard 00:04:07
Bytes sent (initiator:responder) [255:323]
Out SID y.y.y.y[1720:1720]=>x.x.x.x[17168:17168] on ACL outbound
In  SID y.y.y.y[1720:1720]=>x.x.x.x[17168:17168] on ACL inbound  (9 matches)
I played around with the H323 timeout and the TCP idle-timout , this is how I found that the default TCP idle-timeout was causing the disconnect. If I set that timmer to 5min the call disconnects in 5 minutes.
Has anyone come across this problem and be willing to share how they have addressed it. I am continuing to troubleshoot the problem but thought I would post it out there to ask.
--MG
1 REPLY
Hi Michael,
How often do the endpoints send keepalive packets across the TCP/1720 control channel? If the keepalives aren't sent at least once an hour, the idle timeout will kick in and tear down the control channel.
You'll just need to determine the interval of the keepalives and adjust the timeout accordingly.
-Mike
1951
