Hairpinning for Webvpn
Hi!  Its my first time to post here not sure how it works.
Im having problems configuring Hairpinning thru WebVPN but it works with IPSEC.  For testing I tried to used same address-pool and split tunnel policy and already enabled same-security and nat bypass for internal traffic.  Everything works fine IPSEC except for WebVPN and for the WebVPN users they can access resources behind the firewall but not thru haripinning (outside interface).
1 REPLY
Bronze
Jason
Its been a while sicen I have done this, but here is a config that I used a while back for this (asa 8.0.2). The rest of the config as per standard
interface Ethernet0/0
nameif outside
security-level 0
ip address 20.1.1.1 255.255.255.0
same-security-traffic permit intra-interface
ip local pool vpn_user_pool 20.1.1.200-20.1.1.220 mask 255.255.255.0
webvpn
enable outside
svc image disk0:/sslclient-win-1.1.4.176.pkg 1
svc enable
group-policy msw-grp internal
group-policy msw-grp attributes
vpn-tunnel-protocol svc
webvpn
  svc ask none default svc
username mwinnett password vukFd0JFOKL2l7IE encrypted privilege 15
tunnel-group DefaultWEBVPNGroup general-attributes
address-pool vpn_users
address-pool vpn_user_pool
default-group-policy msw-grp
prompt hostname context
ciscoasa(config)# sh vpn-sessiondb svc
Session Type: SVC
Username     : mwinnett               Index        : 6
Assigned IP  : 20.1.1.200             Public IP    : 10.48.67.22
Protocol     : Clientless SSL-Tunnel
Encryption   : RC4                    Hashing      : SHA1
Bytes Tx     : 45779                  Bytes Rx     : 19750
Group Policy : msw-grp                Tunnel Group : DefaultWEBVPNGroup
Login Time   : 17:14:35 UTC Thu Sep 13 2007
Duration     : 0h:01m:02s
NAC Result   : Unknown
VLAN Mapping : N/A                    VLAN         : none
282
