Hairpinning on 8.4 ASA 5505 and above
So, we have put in a branch with only an ASA.  We want to be able to reach the inside interface of the ASA, so that we can use tools for network monitoring, etc. on it.
The inside interface is unreachable from remote VPN locations, though can be reached from inside, and all inside hosts are reachable from the VPN... I have the same-security interface commands in place, but still no go...
I'm missing something, but the nat commands I'm finding are for older versions, and I'm not sure where the problem occurs.  Any help/suggestions are appreciated...
Relevant parts of the config (I think I have them all) listed below:
: Saved
ASA Version 8.4(5)
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
speed 100
duplex full
interface Vlan1
description LAN_NETWORK
interface Vlan2
nameif outside
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object-group network REMOTE_NETWORKS
description REMOTE LOCAL NETWORKS
network-object 10.15.6.0 255.255.254.0
object-group network LAN_NETWORKS
network-object 10.1.3.0 255.255.255.0
access-list CORPORATE_VPN_ACL extended permit ip object-group REMOTE_NETWORKS object-group LAN_NETWORKS
access-list INSIDE_NONAT extended permit ip object-group REMOTE_NETWORKS object-group LAN_NETWORKS
ip verify reverse-path interface inside
ip verify reverse-path interface outside
nat (inside,outside) source static REMOTE_NETWORKS REMOTE_NETWORKS destination static LAN_NETWORKS LAN_NETWORKS
nat (inside,outside) source static REMOTE_NETWORKS REMOTE_NETWORKS destination static NETWORK_MGMT NETWORK_MGMT route-lookup
nat (inside,outside) source dynamic any interface
nat (inside,outside) dynamic interface
  • Firewalling
Everyone's tags (2)
1 ACCEPTED SOLUTION
Super Bronze
Re: Hairpinning on 8.4 ASA 5505 and above
The general form of NAT you should use for the L2L VPN connections is
object network LAN
subnet
object network REMOTE-LAN
subnet
nat (inside,outside) source static LAN LAN destination static REMOTE-LAN REMOTE-LAN route-lookup
I cant be sure if your NAT configuration are correct as you have removed the "inside" interface IP address and have not shared the VPN configuration or routing configuration.
- Jouni
Super Bronze
To reach the "inside" interface through a L2L VPN or Client VPN you will have to add the following global configuration
management-access inside
This will enable you to ICMP the "inside" interface from a site thats behind the VPN connection. Otherwise its not possible
This will also give you the ability to manage the ASA using the IP address of the "inside" interface through the VPN connection.
Hope this helps
- Jouni
Super Bronze
Also,
I would like to confirm the NAT configuration you have above.
It states the source interface as "inside" and destination as "outside". Yet is has an source "object" called REMOTE_NETWORKS which kind of seems strange. But as you say that the connections work through the VPN connection I guess this "object" name rather refers that the network behind "inside" is the network of a remote location?
- Jouni
The nat statement is as above right now.  Whether it is perfect or not, unknown.  Potentially it might need to be inside, inside, but since the VPN connection is to the remote end of the network, not sure what that will affect.  Might need some more insight into that ...
Super Bronze
I am not sure what part of this situation is Hairpinning
I understood that you were trying to reach the "inside" interface through the L2L VPN or VPN Client connection.
I would really need to see more configurations to determine if there is any problem with the configurations.
- Jouni
management-access inside is already enabled.  Not the answer.   Thanks for the suggestion though!
Super Bronze
object network LAN
subnet
subnet
- Jouni
I think you're getting hung up on the terminology.
Change the word Remote to branch and it makes more sense.  Let me try to explain:
: Saved
ASA Version 8.4(5)                          <--- Version on AsA for reference
speed 100
duplex full
interface Vlan1
interface Vlan2
nameif outside
object-group network BRANCHOFFICE_NETWORKS            <--- This is the ASA at the Branch Office, so this is its internal network
description BRANCHOFFICE LOCAL NETWORKS
object-group network LAN_NETWORKS                              <--- These are the networks (there are more than this) at the corporate office
access-list CORPORATE_VPN_ACL extended permit ip object-group BRANCHOFFICE_NETWORKS object-group LAN_NETWORKS
access-list INSIDE_NONAT extended permit ip object-group BRANCHOFFICE_NETWORKS object-group LAN_NETWORKS
nat (inside,outside) source static BRANCHOFFICE_NETWORKS BRANCHOFFICE_NETWORKS destination static LAN_NETWORKS LAN_NETWORKS
nat (inside,outside) source static BRANCHOFFICE_NETWORKS BRANCHOFFICE_NETWORKS destination static NETWORK_MGMT NETWORK_MGMT route-lookup
Thus, I believe the nat statement already covers what you stated.
Super Bronze
What is the source network for the connections that are trying to reach the ASA "inside" interface?
- Jouni
Answer is the route-lookup is missing on the end of the nat command.
Fixed nat command is this:
nat (inside,outside) source static BRANCHOFFICE_NETWORKS BRANCHOFFICE_NETWORKS destination static LAN_NETWORKS LAN_NETWORKS route-lookup
Thanks for the help.
285
