help configuring 5510
I just upgraded an ASA-5510 from 7.0 to 8.4.4-1 and theres a lot of stuff in it I don't recognize that I never added, mostly because of new network objects, nat commands, and other migration stuff. Its been awhile since I've configured the ASA and I think I'd like to start from scratch and clean it up a bit because theres so many lines for so little that I really need. I just think its sort of a mess right now so I was hoping someone could help me with the commands to do the following tasks.
I have a 5510 assigned an IP address on the outside interface with 3 inside interfaces and below are the only requirements I need.
Network-A (192.168.1.0/24)
   - incoming ssh port 2202 goes to node 192.168.1.2
   - incoming ssh port 2203 goes to node 192.168.1.3
   - handle incoming https (443) requests
   - handle incoming www (80) requests
   - cannot see Network-B or Network-C
Network-B (10.0.0.0/16)
   - ssh to nodes on Network-A
   - incoming ssh port 22 goes to node 10.0.0.20
Network-C (192.168.2.0/24)
   - incoming ssh port 2210 goes to node 192.168.2.2
ASA-5510
   - sends logging to syslog node 192.168.1.3 on Network-A
   - there are DNS and NTP servers located outside
Any help much appreciated.
Everyone's tags (2)
1 REPLY
HI ,
this is a whole new installation with 8.4 . you will need to be aware of the folllowing :
-ASA 8.4 configuration guide ( it contains eveything from A to Z) .
http://www.cisco.com/en/US/docs/security/asa/asa84/configuration/guide/asa_84_cli_config.html
- ASA 8.3 and later configuration example :
https://supportforums.cisco.com/docs/DOC-9129
it contains the config for pre 8.3 images and the corrosponding one in 8.3 and later images ( very useful link ).
- Finally remember to use the private ip address in your access-lists ( real ip address and not the translated one ).
HTH .
Mohammad.
327
