Help Configuring a DSL conection via Pix Firewall e515
Can someone guide me on this i'm fairly new on this. i need to configure a Cisco Pix Firewall e515 to connect out to the internet via DSL. Basic Nat and DHCP, basic routing. here is my configuration. Please help me understanding how to configure this properly.
PIX Version 8.0(2)
hostname voyze
domain-name voyze.com
enable  password mW6ETJKBd.1a9jjj encrypted
names
interface  Ethernet0
nameif AT&T
security-level 0
ip address  74.164.6.10 255.255.255.248
ospf cost 10
interface  Ethernet1
nameif inside
security-level 100
ip address  192.168.1.1 255.255.255.0
ospf cost 10
interface Ethernet2
shutdown
no nameif
no security-level
no ip address
passwd  2KFQnbNIdI.2KYOU encrypted
ftp mode passive
dns server-group  DefaultDNS
same-security-traffic permit  inter-interface
same-security-traffic permit intra-interface
object-group  service DM_INLINE_TCP_1 tcp
port-object eq www
port-object eq  https
object-group service DM_INLINE_TCP_2 tcp
port-object eq www
object-group service DM_INLINE_TCP_3 tcp
port-object eq www
object-group service  DM_INLINE_SERVICE_2
service-object tcp eq ftp
service-object  udp eq tftp
object-group service DM_INLINE_SERVICE_1
access-list  inside_access_in extended permit tcp any 68.164.6.8 255.255.255.248  object-group DM_INLINE_TCP_1
access-list AT&T_access_in  extended permit tcp any any object-group DM_INLINE_TCP_3
access-list  AT&T_access_in extended permit object-group DM_INLINE_SERVICE_1  any any
access-list inside_access_in_1 extended permit tcp any any  object-group DM_INLINE_TCP_2
access-list inside_access_in_1 extended  permit object-group DM_INLINE_SERVICE_2 any any
access-list  inside_nat0_outbound extended permit ip 74.164.6.8 255.255.255.248 any
pager  lines 24
logging enable
logging asdm informational
mtu  AT&T 1500
mtu inside 1500
icmp unreachable rate-limit 1  burst-size 1
asdm image flash:/asdm-602.bin
no asdm history enable
arp  timeout 14400
global (AT&T) 101 192.168.1.1-192.168.1.200  netmask 255.255.255.0
nat (inside) 0 access-list inside_nat0_outbound
nat  (inside) 101 74.164.6.8 255.255.255.248
access-group  AT&T_access_in in interface AT&T per-user-override
access-group  inside_access_in_1 in interface inside per-user-override
route  AT&T 0.0.0.0 0.0.0.0 74.164.6.9 1
timeout xlate 3:00:00
timeout  conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout  sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout  sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout  uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http  server enable
http 192.168.1.0 255.255.255.0 inside
no  snmp-server location
no snmp-server contact
snmp-server enable  traps snmp authentication linkup linkdown coldstart
no crypto isakmp  nat-traversal
client-update enable
telnet timeout 5
ssh timeout  5
console timeout 0
dhcpd address 192.168.1.100-192.168.1.200  inside
dhcpd dns 68.94.157.1 interface inside
dhcpd enable inside
threat-detection  basic-threat
threat-detection statistics port
threat-detection  statistics protocol
threat-detection statistics access-list
class-map  inspection_default
match default-inspection-traffic
policy-map  type inspect dns preset_dns_map
parameters
  message-length  maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
   inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect  esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
   inspect xdmcp
  inspect sip
  inspect netbios
  inspect  tftp
service-policy global_policy global
prompt hostname  context
Cryptochecksum:51ef296083714caa6c753b0867bcf405
: end
Everyone's tags (1)
Re: Help Configuring a DSL conection via Pix Firewall e515
Alex,
Here's the configuration guide:
https://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/conf_gd.html
It's for ASA but most configuration is same for PIX 8.0
Note that PIXes and ASAs have only Ethernet (RJ-45 or SFP) connectors. Typically your DSL SP will provide you a RJ-11. You can however do PPPoE on ASA/PIX.
Let me know what you want to do exactly so I may be a bit more specific. Most of the stuff is there in the config guide.
Marcin
Thanks for replying..
This is what i need the pix to do.
1. configure the pix so that it will connect to the internet
2. AT&T is my Dsl Provider.
3. the pix is configured. but is not going out to the internet.
Please Take a look at my config and tell me whats missing. this should be straight forward connection. but is not working.
Thanks.
Alex,
Are you able to ping anything on the internet from PIX?
(Note: you might need to add "icmp perm any outside" to config)
Note that your NAT seems screwed up. I'll add an edit soon with suggestions.
edit:
no access-list  inside_nat0_outbound extended permit ip 74.164.6.8 255.255.255.248 any
no global (AT&T) 101 192.168.1.1-192.168.1.200  netmask 255.255.255.0
no nat (inside) 0 access-list inside_nat0_outbound
no nat  (inside) 101 74.164.6.8 255.255.255.248
nat (inside) 1 0 0
global(AT&T) 1 interface
This should make sure that all traffic from inside is being PATed to outside interface's IP address.
edit 2:
If you want to test ICMP from inside to internet add "fixup proto icmp"
im still runinng into problems. below is my config can you tell me what to change to connect to the Internet?
: Saved
: Written by enable_15 at 21:13:54.534 UTC Wed Jul 7 2010
PIX  Version 8.0(2)
hostname pixfirewall
names
interface Ethernet0
nameif  Outside
  security-level 0
interface  Ethernet1
nameif inside
security-level 100
interface Ethernet2
shutdown
no  nameif
  no security-level
no ip address
ftp mode passive
access-list inside_access_in extended  permit tcp any any eq www
pager lines 24
mtu inside 1500
mtu Outside 1500
arp timeout 14400
access-group  inside_access_in in interface inside
route inside 0.0.0.0  255.255.255.0 74.164.6.9 1
http server enable
telnet timeout  5
ssh timeout 5
console timeout 0
dhcpd address  192.168.1.2-192.168.1.254 inside
dhcpd enable inside
parameters
  inspect  ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
   inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect  skinny
   inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect  netbios
  inspect tftp
tftp-server  inside 192.168.1.22 /cisco
Cryptochecksum:
44e94eadfa2d05328020ce6ec29eb580
Alex,
I would definetly change that route:
to
route inside 0.0.0.0  0.0.0.0 74.164.6.9 1
Secondly:
You should at least also allow DNS! For your users to be able to browse internet!
But honestly do not apply inbound accless-list on inside interface unless you don't need it.
I don't see any NAT configuration .. so your inside users will not be NATed when going out to the internet.
nat (inside) 100 0 0
global (outside) 100 interface
That should take care of NAT.
Once you apply those changes please apply my sugestions from posts below (pinging fromPIX itself to test connectivity to internet etc)
Marcin
Hello Marcin,
I'm still working it out. this time i added ppoe . can you please assist. or do you think you can help me offline with this?
Please from the kindness of your heart.
this is the config i have by adding ppoe. what do you think?
Also keep in mind i am using ASDM to configure the box. thanks
Result of the command: "show running-config"
: Saved
PIX Version 8.0(2)
names
interface Ethernet0
nameif Outside
security-level 0
pppoe client vpdn group AT&T
ip address pppoe
interface Ethernet1
nameif inside
security-level 100
interface Ethernet2
shutdown
no nameif
no security-level
no ip address
ftp mode passive
dns domain-lookup Outside
dns domain-lookup inside
name-server 68.94.156.1
name-server 68.94.157.1
pager lines 24
mtu Outside 1500
mtu inside 1500
arp timeout 14400
global (Outside) 101 interface
nat (inside) 101 0.0.0.0 0.0.0.0
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn group AT&T request dialout pppoe
vpdn group AT&T localname rafaelpadilla4953@att.net
vpdn group AT&T ppp authentication pap
vpdn username mert2010stw@att.net password *********
dhcpd enable inside
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
Cryptochecksum:ccc2eb63ab1f84b377509e0e80768326
: end
Alex,
Considering that we're in different timezones it might be a problem - I'm usually checing forums late at night :-)
Few notes, provided that your pppoe is working I would do this:
interface Ethernet0
ip address pppoe setroute
Now with this in place ASA should put a default route based on what we negotiate via pppoe.
So you might as well remove old route:
no route inside 0.0.0.0 0.0.0.0 74.164.6.9 1
On old bug quite good guide:
http://cisco.biz/en/US/products/ps6120/products_configuration_example09186a0080ab7ce9.shtml
(Both CLI and ASDM)
Marcin
814
