Help Configuring PIX and VPN Client
dlgoodson
Here is the code, what could cause the vpn client not to connect.
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 remotes security10
domain-name x.org
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
fixup protocol sip udp 5060
names
access-list nonat permit ip 10.10.0.0 255.255.255.0 10.10.255.0 255.255.255.0
access-list nonat permit ip 10.10.10.0 255.255.255.0 10.10.255.0 255.255.255.0
access-list nonat permit ip 10.10.20.0 255.255.255.0 10.10.255.0 255.255.255.0
access-list nonat permit ip 10.10.30.0 255.255.255.0 10.10.255.0 255.255.255.0
access-list nonat permit ip 10.10.40.0 255.255.255.0 10.10.255.0 255.255.255.0
access-list nonat permit ip 10.10.50.0 255.255.255.0 10.10.255.0 255.255.255.0
access-list nonat permit ip 10.10.100.0 255.255.255.0 10.10.255.0 255.255.255.0
access-list nonat permit ip 192.x.x.0 255.255.255.0 10.10.255.0 255.255.255.
access-list nonat permit ip 10.10.x.0 255.255.255.0 10.10.255.0 255.255.255.0
access-list nonat permit ip 10.10.1.0 255.255.255.0 10.10.255.0 255.255.255.0
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
icmp permit any outside
icmp permit any inside
icmp permit any remotes
mtu outside 1500
mtu inside 1500
mtu remotes 1500
ip address outside x.x.x.3 255.255.255.0
ip address inside 10.10.30.254 255.255.255.0
ip address remotes 10.10.220.2 255.255.255.0
ip local pool bigpool 10.10.255.1-10.10.255.254
global (outside) 1 x.x.x.129
global (remotes) 1 10.10.220.5
nat (inside) 0 access-list nonat
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
nat (remotes) 1 0.0.0.0 0.0.0.0 0 0
conduit permit icmp any any
route outside 0.0.0.0 0.0.0.0 74.255.101.1 1
route inside 10.10.1.0 255.255.255.0 10.10.30.1 1
route inside 10.10.10.0 255.255.255.0 10.10.30.1 1
route inside 10.10.20.0 255.255.255.0 10.10.30.1 1
route inside 10.10.40.0 255.255.255.0 10.10.30.1 1
route inside 10.10.50.0 255.255.255.0 10.10.30.1 1
route inside 10.10.60.0 255.255.255.0 10.10.30.1 1
route inside 10.10.70.0 255.255.255.0 10.10.30.1 1
route inside 10.10.100.0 255.255.255.0 10.10.30.1 1
route inside 10.10.201.0 255.255.255.0 10.10.30.1 1
route inside 10.10.202.0 255.255.254.0 10.10.30.1 1
route inside 10.10.204.0 255.255.254.0 10.10.30.1 1
route inside 10.10.210.0 255.255.255.0 10.10.30.1 1
route inside 10.10.254.0 255.255.255.0 10.10.30.1 1
route inside 192.168.2.0 255.255.255.0 10.10.30.1 1
route inside 192.168.193.0 255.255.255.0 10.10.30.1 1
aaa-server TACSERVER (inside) host 10.10.30.200 library timeout 10
aaa-server FCLRADIUS (inside) host 10.10.30.200 library timeout 10
url-server (inside) vendor n2h2 host 10.10.30.6 port 4005 timeout 5 protocol TCP
aaa authentication telnet console TACSERVER
filter url http 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0
http server enable
http 10.10.20.0 255.255.255.0 inside
http 10.10.30.0 255.255.255.0 inside
snmp-server host inside 10.10.200.230 poll
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
vpngroup fclvpn address-pool bigpool
vpngroup fclvpn dns-server x.133.x.4
vpngroup fclvpn idle-time 1800
vpngroup fclvpn password ********
telnet 10.10.30.0 255.255.255.0 inside
telnet 10.10.20.0 255.255.255.0 inside
froggy3132000
Level 3
Level 3
sysopt connection permit-ipsec
isakmp enable outside
no sysopt route dnat
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map library 1 set transform-set myset
crypto map fcl 20 ipsec-isakmp dynamic library
crypto map fcl client authentication FCLRADIUS
crypto map fcl interface outside
isakmp key ******** address 0.0.0.0 netmask 0.0.0.0
isakmp identity address
isakmp client configuration address-pool local bigpool outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
