HELP Erased Flash on ASA 5505
Hi All.
One of my junior technicians decided to erase the flash memory of our new ASA5505. This being the first ASA that we've had, I didn't think much, as I can treat it like a router...welll..... I booted it into ROMMON to copy the image from the TFTP server, on my connected laptop.
I've entered the following variables:
ADDRESS=192.168.0.25
SERVER=192.168.0.110
GATEWAY=192.168.0.110
PORT=Ethernet0/0
VLAN=untagged
IMAGE=
CONFIG=
LINKTIMEOUT=20
PKTTIMEOUT=4
RETRY=20
My problem seems to be that when I enter the variable for the IMAGE:
image asa721-k8.bin
All I get is the error message that the command is wrong.
I can ping the server (.110) and everything else is correct. I'm connected via Serial/HyperTerminal and then the network cable going into 0/0.
Can someone help?
1 ACCEPTED SOLUTION
Gold
Re: HELP Erased Flash on ASA 5505
i think you want the following command:
file asa721-k8.bin
then enter:
tftp
this assumes your asa721-k8.bin file is on a tftp server at 192.168.0.110
Gold
file asa721-k8.bin
then enter:
tftp
File........
That would make sense.
image is set again.
My thanks to you Srue.
Okay, this has been resolved, however the ASDM launcher will not connect to it.
I don't have any experience with ASDM. Can anyone lend a hand?
Gold
you'll need to load the asdm image - assuming it was also erased by your junior engineer.
access to asdm is similar to granting access to telnet/ssh.
http server enable
http 192.168.1.1 255.255.255.255 inside
change 192.168.1.1/32 to whatever host(s) you want to have access to asdm.
be sure to use https. when prompted for a username/passwd, just enter the enable password , leaving the username blank. You'll need java 1.4.2 or higher wherever you're accessing it from.
Have you copied the ASDM image to the flash if not copy the asdm image to the flash as you copied the .bin fine
and give the path asdm image disk0:/asdmXXX.bin in the config mode
582
