09-21-2010 05:47 AM - edited 03-11-2019 11:43 AM
Hi, i have a question about software upgrade ASA 8.2 to 8.3
The problem/question is about NAT
pre-8.3
object-group network DM_68
network-object 10.27.0.0 255.255.0.0
network-object 10.32.0.0 255.255.0.0
network-object 10.47.0.0 255.255.0.0
network-object 192.168.104.0 255.255.255.0
network-object host 192.168.20.1
access-list nonat extended permit ip object-group DM_68 192.168.95.0 255.255.255.128 (no nat per VPN remote net 192.168.95.0)
nat (inside) 0 access-list nonat
nat (inside) 4 192.168.95.0 255.255.255.128
global (outside) 4 174.49.8.45
8.3 configuration
i removed the access list that is still preset (correct?? i must remove this ACL ???)
no access-list nonat extended permit ip object-group DM_68 192.168.95.0 255.255.255.128
network behind the INSIDE interface
nat (inside,any) source static DM_68 DM_68 destination static obj-192.168.95.0 obj-192.168.95.0
removedi unidirectional at the end fo the nat line. (Correcto to remove unidirectional??)
object network obj-192.168.95.0
subnet 192.168.95.0 255.255.255.128
nat (inside,outside) dynamic 174.49.8.45
I want to know
1) is correct the conversione 8.2 to 8.3?
2) I need that if a packet from the net 192.168.104.0 that is in the DM_68 object group try to contact a server in the net 192.168.95.0 net it goes via VPN without nat,
but if one ip of the net 192.168.104.0 try to go to internet is natted with the ip 174.49.8.45. is correct the 8.3 configuration ??
Thanks a lot to all
09-21-2010 06:26 AM
That looks correct.
Yes, you do not need the no-nat acl.
Yes, you need to remove the unidirectional key word as well.
Refer this one:https://supportforums.cisco.com/docs/DOC-12569
-KS
09-21-2010 06:34 AM
thanks a lot ,i have another duobt,
this statement
is only for VPN, so i can refine this statement changing any with outside
correct?
but there is not a problem or with this other statement in the obj-192.168.95.0 ??
Thanks a lot , thanks vary much
09-21-2010 06:42 AM
Yes, you absolutely can. More specific the better. Plus that destination network only lives off the outside.
-KS
09-21-2010 06:59 AM
Thanks a lot next week i will go to the customer to deliver the upgrade..i hope that all works
thanks a lot
