Help needed in ASA 5540 Cluster/Failover setup
Hello expert,
                    Currently we have two asa in our Datacenter setup as a Active/Standby failover setup and tested ie failover is working,(if one FW goes down), but what if a the uplink switches/links or backend switches go down, how does the active fw knows to failover ?
Current setup
    ___|___                              __|___
---| SW 1 |------------------------ | Sw2   |
    ___|___                              __|___
---| FW 1 |------------------------ | FW-2 |
    ___|___                              __|___
In the above figure, FW1 is active and I have powerd off the uplink  SW1, but the FW2 did not take over, and the same for backend switches, So how do I configure my FW's so that any of the uplink or back end switches go down, the Active should give its role to standby to forward the traffice from a different switch ie sw2 in case sw1 goes down.
Or Is there any mechanisim where I can monitor the interfaces ie uplinks or back end links etc ?
Your help is appreciated.
Silver
It seems that you have LAN link directly connected between the boxes, so the unit will determine that Primary/Active has interfaces that are inactive and failover. You should read:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml
This link gives you the failover triggers and failover actions.
Value our effort and rate the assistance!
Re: Help needed in ASA 5540 Cluster/Failover setup
Thanks Jumora,
                        I will have a look into this and will let you know.
H Khan
VIP Purple
if the failure of a directly connected device (that results in a link-down event on the ASA) doesn't trigger the failover it's nearly always a misconfiguration of the "monitor-interface" commands where the config tells the ASA that an interface is not "important enough" to trigger a failover.
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
Thanks Karsten,
H Khan
Silver
Please rate our assistance!!!
Silver
any progress on this?
219
