Bronze
Help Needed with ASA 8.3+ NAT
I'm having an issue configuring NAT on an ASA running 8.3. Hopefully someone can point me in the right direction.
I've managed to configure NAT from the Inside interface to the DMZ, using PAT, so that the traffic is hidden behind the IP of the DMZ interface. This seems to work ok.
object network obj_any-18
subnet 0.0.0.0 0.0.0.0
nat (inside,dmz1.005) dynamic interface
The problem I have is when I try to configure a rule for traffic that originates in the DMZ back to the Inside. I can't seem to get any traffic to flow from the DMZ to the Inside, and sometimes I manage to stop traffic flowing in both directions!
What would be the best way to configure the return traffic from the DMZ to the Inside.
Paul
HTH Paul ****Please rate useful posts****
Everyone's tags (4)
Red
I hope you not using the same object network again for it, since you cannot do that with auto nat, try this:
object network obj_any-100
   nat (dmz1.005,inside) dynamic interface
Moreover what device are you using?? is it 5505?? what license does it have??
Varun Rao
Security Team,
Cisco TAC
Thanks, Varun Rao Security Team, Cisco TAC
Bronze
Hi Varun,
I tried that config already using a different unused 0.0.0.0 0.0.0.0 object. When applied traffic doesn't flow in either direction, when removed traffic flows from the inside to dmz as per config above.
I'm using a cisco asa 5510, with a security plus license.
Paul
Red
Can you share your configuration??
Varun Rao
Security Team,
Cisco TAC
Bronze
Do you just want the NAT parts, or the entire config?
Red
nat, routes,acl should be fine
Varun Rao
Security Team,
Cisco TAC
Bronze
Re: Help Needed with ASA 8.3+ NAT
Hi Varun,
ACLs and NAT config attached. All routing is learnt via OSPF.
The NAT statements in the config are all from the 8.3 upgrade process, with the exception of the Inside, dmz1.005 statements.
Paul
Red
Hi Paul,
can you please tell me the purpose for this nat statement in your configuration:
nat (dmz1.005_8.3_nat_test,inside) source static net_dmz1.005 net_dmz1.005 destination static grp_dmz1.005_nonat grp_dmz1.005_nonat unidirectional
I guess this might interfere, can you do this, add a nat:
nat (dmz1.005_8.3_nat_test,inside) 1 source dynamic any interface
and test again.
I might need your complete configuration to check other things, you can PM me if you want.
Varun Rao
Security Team,
Cisco TAC
Bronze
Hi Varun,
I think that may have been left in there whilst I was testing!
I'll remove it and add the nat you suggested, but I can't do that until I'm back in the office tomorrow am.
Thanks for you help so far
Paul
Red
No Issues, do let me know how it goes
Bronze
Hi Varun,
I have removed the nat statement below from the config;
And then added;
Traffic doesn't flow in either direction now.
If I disable the new nat statement, I can ping from the inside to dmz1.005, and the IP is hidden behind the dmz1.005 interface. But I can't ping in the other direction.
Do you want me to PM you the config?
Paul
Red
Hi Paul,
Yes please, you can PM me the config, I'll try at my end
Varun Rao
Security Team,
Cisco TAC
Bronze
Hi Varun,
Did you get my PM ok?
Paul
546
