Help on a NAT question
I thought this would be simple at first but I seem to be getting a little stuck on it.  I need to forward ports 80,443,51111 to internal hosts.  80 and 443 need to go to my web server (192.168.5.15) while 51111 needs to go to another server (192.168.5.91).  All requests are coming in on public static IP 96.249.x.x.  I have 80 and 443 working fine to my web server but can't wrap my head around how to forward 51111 to a different host accessed by the same public IP.  Any help would be greatly appreciated.
Here are the important parts of my config:
interface Vlan2
description Connection to Primary ISP (FiOS)
nameif primaryisp
security-level 0
ip address 96.249.x.x 255.255.255.248
interface Vlan5
description Connection to internal internet access subnet (192.168.5.0/24)
nameif inside
security-level 100
ip address 192.168.5.1 255.255.255.0
object network asp-wss-3-vz
host 192.168.5.15
access-list outside_access_in_1 remark Access list to allow outside traffic in
access-list outside_access_in_1 remark **********
access-list outside_access_in_1 remark Allow traffic into Web Server on 80 and 443
access-list outside_access_in_1 extended permit tcp any object asp-wss-3-vz eq www
access-list outside_access_in_1 extended permit tcp any object asp-wss-3-vz eq https
nat (inside,primaryisp) static 96.249.x.x
Thanks in advanced!
Everyone's tags (1)
You might try :
object network OTHER
host 192.168.5.91
nat (inside,primaryisp) static interface service tcp 51111  51111
object network WEB-HTTP
host 192.168.5.15
nat (inside,primaryisp) static interface service tcp www www
object network WEB-HTTPS
host 192.168.5.15
nat (inside,primaryisp) static interface service tcp https https
Dan
Thanks.  I ended up getting it to work using that method.  Anyone know of a better way though?  I have 3 servers that run http and https, 1 server that needs 51111 and 2 ISPs (primary/backup using ip sla).  That means I have like 14 objects and nat rules and access list rules.  See below...
object network asp-wss-3-http-tw
host 192.168.5.15
object network asp-wss-3-http-vz
host 192.168.5.15
object network vpn-ip-pool
subnet 10.0.0.0 255.255.255.0
object network my-mgmt
subnet 172.16.20.0 255.255.255.0
object network inside172
subnet 172.16.2.0 255.255.255.0
object network asp-sc-1-http-tw
host 192.168.5.21
object network asp-sc-1-http-vz
host 192.168.5.21
object network asp-sc-2-http-tw
host 192.168.5.24
object network asp-sc-2-http-vz
host 192.168.5.24
object network asp-wss-3-https-tw
host 192.168.5.15
object network asp-wss-3-https-vz
host 192.168.5.15
object network asp-sc-1-https-tw
host 192.168.5.21
object network asp-sc-1-https-vz
host 192.168.5.21
object network asp-sc-2-https-tw
host 192.168.5.24
object network asp-sc-2-https-vz
host 192.168.5.24
object network asp-routerpc-tw
host 192.168.5.91
object network asp-routerpc-vz
host 192.168.5.91
access-list outside_access_in_1 extended permit tcp any object asp-wss-3-http-tw eq www
access-list outside_access_in_1 extended permit tcp any object asp-wss-3-https-tw eq https
access-list outside_access_in_1 extended permit tcp any object asp-wss-3-http-vz eq www
access-list outside_access_in_1 extended permit tcp any object asp-wss-3-https-vz eq https
access-list outside_access_in_1 remark Allow access into sc-1 on 80 and 443
access-list outside_access_in_1 extended permit tcp any object asp-sc-1-http-tw eq www
access-list outside_access_in_1 extended permit tcp any object asp-sc-1-https-tw eq https
access-list outside_access_in_1 extended permit tcp any object asp-sc-1-http-vz eq www
access-list outside_access_in_1 extended permit tcp any object asp-sc-1-https-vz eq https
access-list outside_access_in_1 remark Allow access into sc-2 on 80 and 443
access-list outside_access_in_1 extended permit tcp any object asp-sc-2-http-tw eq www
access-list outside_access_in_1 extended permit tcp any object asp-sc-2-https-tw eq https
access-list outside_access_in_1 extended permit tcp any object asp-sc-2-http-vz eq www
access-list outside_access_in_1 extended permit tcp any object asp-sc-2-https-vz eq https
access-list outside_access_in_1 remark Allow traffic to Lukes Router program on port 51111
access-list outside_access_in_1 extended permit tcp any object asp-routerpc-tw eq 51111
access-list outside_access_in_1 extended permit tcp any object asp-routerpc-vz eq 51111
nat (inside,backupisp) static 208.125.x.x service tcp www www
nat (inside,primaryisp) static 96.249.x.x service tcp www www
nat (inside,primaryisp) static 96.248.x.x service tcp www www
nat (inside,backupisp) static 208.125.x.x service tcp https https
nat (inside,primaryisp) static 96.249.x.x service tcp https https
nat (inside,primaryisp) static 96.248.x.x service tcp https https
object network asp-lukerouterpc-tw
nat (inside,backupisp) static 208.125.x.x service tcp 51111 51111
object network asp-lukerouterpc-vz
nat (inside,primaryisp) static 96.249.x.x service tcp 51111 51111
473
