Help on cisco ASA 5505 and enable ASDM!!!
I having problem when I try to change interface Ethernet0/1 to switchport access vlan 1, but when I try to monitor it using the run command it does not appear. What do I need to do to make it work? And also what is my next step so that I could access ASDM on my web browser? The ios I use is asa843-k8.bin and asdm-647.bin on ASA 5505.
: Saved
ASA Version 8.4(3)
hostname ciscoasa
enable password 2KFQnbNIdI.2KYOU encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-647.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) dynamic interface
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.5-192.168.1.36 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
Cryptochecksum:ec3006dc4cab42f81d133b398ddb0b6c
: end
Re: Help on cisco ASA 5505 and enable ASDM!!!
is k9 active ? Do you connect to Asa from vista/win7?
its been a while since I played with 5505, but I think all the interfaces are part of vlan 1 by default..hence it is not shown in the running config.
try sh run all interface
for the HTTP the following commands are already there.
http server enable
what you need is the following
username ADMIN password WHATEVER priv 15
aaa authentication http console LOCAL
Please mark complete and also rate if my reply was helpful to you.
Thank you.
If k9 not active and vista/win7 used to connect to Asa via https , Asa will.drop connection because DES not supported by default in vista/win7 SSL ciphers
Thank you so much for your reply.
Yes, my OS is Win 7
How can I active k9
So what is your recommendation
I'm using Win7. Could someone show me their outpu on asa 5505 so that I could compare it to mine? Thanks
This is my output:
ciscoasa# show run
: Saved
ASA Version 8.4(3)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.10.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ftp mode passive
pager lines 24
mtu inside 1500
mtu outside 1500
arp timeout 14400
aaa-server asdm protocol tacacs+
accounting-mode simultaneous
user-identity default-domain LOCAL
aaa authentication secure-http-client
http server enable
http 192.168.10.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.10.5-192.168.10.36 inside
dhcpd enable inside
webvpn
username ADMIN password xlaEBzC9eIymxW7v encrypted privilege 15
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
call-home reporting anonymous prompt 2
Cryptochecksum:91ec6c81a5b77bb7da9743edafe60cc0
: end
Below is the command that I ran but the show run command doesn't show the changes that I want. Please help me on this issue.
ciscoasa# conf t
ciscoasa(config)# int e
ciscoasa(config)# int ethernet 0/1
ciscoasa(config-if)# no shut
ciscoasa(config-if)# switch
ciscoasa(config-if)# switchport access vlan 1
ciscoasa(config-if)# exit
ciscoasa(config)# exit
ciscoasa# show run
: Saved
ASA Version 8.4(3)
hostname ciscoasa
names
As noted on this thread, vlan1 is the default vlan so you will not see this in the running config.
Regards Craig
have you tried my above recomendation?
also have you verified that your image is K9... a show ver would help
I used asdm-647.bin. What else do I need to do to make it work?  When I used Cisco ASDM Launcher it pop up as Unable to launch device from 192.168.1.1.
ciscoasa# show version
Cisco Adaptive Security Appliance Software Version 8.4(3)
Device Manager Version 6.4(7)
Compiled on Fri 06-Jan-12 10:24 by builders
System image file is "disk0:/asa843-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 48 mins 49 secs
Hardware:   ASA5505, 256 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash M50FW080 @ 0xfff00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
                             Boot microcode        : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode     : CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode       : CNlite-MC-IPSECm-MAIN-2.06
                             Number of accelerators: 1
0: Int: Internal-Data0/0    : address is 001b.5446.d78a, irq 11
1: Ext: Ethernet0/0         : address is 001b.5446.d782, irq 255
2: Ext: Ethernet0/1         : address is 001b.5446.d783, irq 255
3: Ext: Ethernet0/2         : address is 001b.5446.d784, irq 255
4: Ext: Ethernet0/3         : address is 001b.5446.d785, irq 255
5: Ext: Ethernet0/4         : address is 001b.5446.d786, irq 255
6: Ext: Ethernet0/5         : address is 001b.5446.d787, irq 255
7: Ext: Ethernet0/6         : address is 001b.5446.d788, irq 255
8: Ext: Ethernet0/7         : address is 001b.5446.d789, irq 255
9: Int: Internal-Data0/1    : address is 0000.0003.0002, irq 255
10: Int: Not used            : irq 255
11: Int: Not used            : irq 255
The Running Activation Key is not valid, using default settings:
Licensed features for this platform:
Maximum Physical Interfaces       : 8              perpetual
VLANs                             : 3              DMZ Restricted
Dual ISPs                         : Disabled       perpetual
VLAN Trunk Ports                  : 0              perpetual
Inside Hosts                      : 10             perpetual
Failover                          : Disabled       perpetual
VPN-DES                           : Enabled        perpetual
VPN-3DES-AES                      : Disabled       perpetual
AnyConnect Premium Peers          : 2              perpetual
AnyConnect Essentials             : Disabled       perpetual
Other VPN Peers                   : 10             perpetual
Total VPN Peers                   : 12             perpetual
Shared License                    : Disabled       perpetual
AnyConnect for Mobile             : Disabled       perpetual
AnyConnect for Cisco VPN Phone    : Disabled       perpetual
Advanced Endpoint Assessment      : Disabled       perpetual
UC Phone Proxy Sessions           : 2              perpetual
Total UC Proxy Sessions           : 2              perpetual
Botnet Traffic Filter             : Disabled       perpetual
Intercompany Media Engine         : Disabled       perpetual
This platform has a Base license.
Serial Number: JMX1116Z0TP
Running Permanent Activation Key: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
Configuration register is 0x1
Configuration last modified by enable_15 at 01:09:27.579 UTC Mon Mar 12 2012d
Hello Tho Vo,
As already explained all ports that  are part of vlan 1 are assigned to the default vlan so no matter how many times you run the command show run you will not see it, Although you can run show run interface x/x and you should see the configuration there
Regarding the HTTPS problem you could get the 3DES/AES license for free.
Go to the following link and do it so you can have this:
https://tools.cisco.com/SWIFT/LicensingUI/loadDemoLicensee?FormId=139
Afterwards add the command
ssl encryption aes128-sha1 3des-sha1 aes256-sha1
And you should be good to go
Remember to rate all of the helpful posts
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
I for the life of me couldn't
I for the life of me couldn't figure out why I couldn't get my ASDM to load with all the proper configs and license.
The command: ssl encryption aes128-sha1 3des-sha1 aes256-sha1
is the one that you need to use to get ASDM up a running through web.  Thanks for this.
you can't because 3des is disabled. browser doesnt support des. you can check ssl handshake and you will see supported ciphers on both side.
solution:
1) connect from win xp (vista and win 7 doesnt support des on ssl)
2) install ASDM from cisco site (from installer) and connect to device
3) connect from console (com port)
also you can't use strong encryption with VPN, ssh2. iphone\ipad will not work. anyconnect will work from win xp
ciscoasa(config)# aaa authentication http console local
ERROR: aaa-server group local does not exist
Usage: [no] aaa mac-exempt match
        [no] aaa authentication secure-http-client
        [no] aaa authentication listener http|https [port ] [redirect]
        [no] aaa authentication|authorization|accounting include|exclude
        [no] aaa authentication serial|telnet|ssh|http|enable console
                [LOCAL]
        [no] aaa accounting telnet|ssh|serial|enable console
        [no] aaa authentication|authorization|accounting match
        [no] aaa authorization command {LOCAL | [LOCAL]}
        [no] aaa accounting command {privilege }
        [no] aaa proxy-limit | disable
        [no] aaa local authentication attempts max-fail
        clear configure aaa
        clear aaa local user {fail-attempts|lockout} {all | username }}
        show running-config [all] aaa [authentication|authorization|accounting
                |max-exempt|proxy-limit]
        show aaa local user [lockout]
                [LOCAL]
        clear configure aaa
astonishing as it may seem, the "LOCAL" keyword is case-sensitive in:
Try it in uppercase.
-- Jim Leinweber, WI State Lab of Hygiene
As stated, the default VLAN1 will not show up on the port assignement part of the runtime config display.  I did note you will need to make a default route to allow hosts on private lans or dmzs to reach the internet.
8637
