HELP! password recovery for pix 501
I have followed the instructions on this link to the letter http://www-tss.cisco.com/eservice/compass/common/activities/password_PIX.htm#sample and my firewall will actually recieve the bin file but will not load and refuses to give me the y/n prompt to erase the password.Please I need help.I also learnt that this procedure can only be used on a 515 pix,i need what can work on a 501
Re: HELP! password recovery for pix 501
No, this does not work - i get the same. In fact i tftp the .bin file and then get an error - my pck tracer from the tftp server demonstrates the pix is declaring that it's event log is full.
All 12 blocks of .bin file downloads and i get an error messg from the pix. HERE is info from the pix and 5 or 6 packets traced from my TFTP server
Config from PIX (running 6.3 (5))
monitor> server 10.110.0.250
server 10.110.0.250
monitor> gateway 10.110.1.0
gateway 10.110.1.0
monitor> interface 1
0: i8255X @ PCI(bus:0 dev:17 irq:9 )
1: i8255X @ PCI(bus:0 dev:18 irq:10)
Using 1: i82557 @ PCI(bus:0 dev:18 irq:10), MAC: 0016.c7f9.e440
monitor> address 10.110.45.109
monitor> file np63.bin
file np63.bin
monitor>
monitor> ping 10.110.0.250
Sending 5, 100-byte 0x89b6 ICMP Echoes to 10.110.0.250, timeout is 4 seconds:
Success rate is 100 percent (5/5)
monitor> tftp
tftp np63.bin@10.110.0.250 via 10.110.1.0.............
TFTP failed (return:-10 arg:0x0)
monitor>
Packets traced from TFTP Server (I use Solar winds TFTP server)
No. Time Source Destination Protocol Info
1047 55.578984 10.110.45.109 10.110.0.250 TFTP Acknowledgement, Block: 13
Frame 1047 (60 bytes on wire, 60 bytes captured)
Ethernet II, Src: Cisco_3b:4d:67 (00:0a:f4:3b:4d:67), Dst: Dell_97:be:b8 (00:13:72:97:be:b8)
Internet Protocol, Src: 10.110.45.109 (10.110.45.109), Dst: 10.110.0.250 (10.110.0.250)
User Datagram Protocol, Src Port: 42638 (42638), Dst Port: tftp (69)
Trivial File Transfer Protocol
1048 55.579028 10.110.45.109 10.110.0.250 TFTP Acknowledgement, Block: 13
Frame 1048 (60 bytes on wire, 60 bytes captured)
Ethernet II, Src: Cisco_3b:4d:29 (00:0a:f4:3b:4d:29), Dst: Dell_97:be:b8 (00:13:72:97:be:b8)
1049 55.579030 10.110.0.250 10.110.45.109 TFTP Error Code, Code: Not defined, Message:
I was having a weird issue with SolarWinds TFTP server a few days ago. I decided to try another TFTP server so I went and installed PumpkIN and it started working.
I don't know if it will solve your problem but if you try with another TFTP server you can determine where the problem is (the server or the PIX) :).
Paulo
Rest of packets
Frame 1049 (89 bytes on wire, 89 bytes captured)
Ethernet II, Src: Dell_97:be:b8 (00:13:72:97:be:b8), Dst: Cisco_f9:e4:40 (00:16:c7:f9:e4:40)
Internet Protocol, Src: 10.110.0.250 (10.110.0.250), Dst: 10.110.45.109 (10.110.45.109)
User Datagram Protocol, Src Port: tftp (69), Dst Port: 42638 (42638)
1050 55.579945 10.110.45.109 10.110.0.250 TFTP Acknowledgement, Block: 13
Frame 1050 (60 bytes on wire, 60 bytes captured)
Ethernet II, Src: Cisco_f9:e4:40 (00:16:c7:f9:e4:40), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
1051 55.579980 10.110.0.250 10.110.45.109 TFTP Error Code, Code: Not defined, Message:
Frame 1051 (89 bytes on wire, 89 bytes captured)
1052 55.580228 10.110.45.109 10.110.0.250 TFTP Acknowledgement, Block: 13
Frame 1052 (60 bytes on wire, 60 bytes captured)
1053 55.580277 10.110.45.109 10.110.0.250 TFTP Acknowledgement, Block: 13
464
