Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Help setting up PDM for PIX 525
Hello all,
I'm not really experienced with the PIX firewalls, but I do have a good knowledge of the basic IOS for the routers/switches.
Anyway, I have a Pix 525 firewall that has its interfaces, etc. already set up with IPs. My one question is on how to access the PDM. I assume this is done through the web browser? I've been reading some conflicting documents. One says the PDM is already loaded into flash memory, another sort of indicates that it may have to be flashed via tftp first.
Could somebody shed some light on this? My config is as follows: IOS v.6.3
When I run 'setup' in global config, I have IP addresses for the outside/inside interfaces, however the field 'IP address of host running PIX Device Manager' is blank by default. Any help on this would be greatly appreciated, thank you.
Re: Help setting up PDM for PIX 525
to prepare PIX for browser access.
pix(config)#http server enable
this tells pix any host inside your network can access pix via browser from interface inside
pix(config)#http inside
if you want to be more granular you may do it by subnet
if you want to do it by source Ip instead
same priciple from above applies for telnet access
pix(config)#telnet inside
same principle for interface name by replacing
inside with proper nameif interface name.
just pix code 6.x you cannot telnet to outside interface nor http but you can ssh from outside to pix outside interface.
in pix code 7.x and above you may telnet/ssh/and http from outside world to outside interface.
to access pix from browser, you may need to update Java pugins if you still cannot access the pix through browser, I don't have the link handy for IE java plug ins but will look for it in case you have problems just post your results.
for username leave blank
for password: enter enable password.
for the inside interface you will need to configure that interface with IP address of your choice, once the inside interfac is configured make sure your PC is in the same subnet as pix inside subnet and try accessing it.
configure inside interface, I have not interact with your model but 500 series follow almost same interface type names, here is example to configure inside interface, the keyword nameif followed by ethernet1 inside that name inside can be anything you want most people use name inside.
interface ethernet1 100full
nameif ethernet1 inside security100
ip address inside
pls rate any helpful post if it helps
Community Member
Yes, Thank you, I will try it and let you know more.
